Misfire 1971 Pontiac 455 YC Block
2090 Views 44 Replies 10 Participants Last post by  Bopman
So I have a misfire on cylinder number 7. The distributor was changed to a Delco Remy HEI. It ran fine when I bought it. I have changed wires, plugs, cap and rotor and still have a misfire on number 7 cylinder. I did a compression check on All the cylinders and it’s at 180- 185 psi across all cylinders. Number 7 cylinder was 183. I changed plugs that I know that were firing into number seven cylinder, and changed wires that I knew were firing and still when I pull the plug wire off of number 7 cylinder when it’s running there’s no difference. The engine still sounds the same with the same misfire. When I pull the plug in cylinder 7 it looks wet. What should the gap be on spark plugs on a 71 455? Any Help would be greatly appreciated
21 - 40 of 45 Posts
OK. Then my money would be on the poly lock being incorrectly adjusted just a little too tight and holding the valve open just enough so it does not seat tightly.
When you back the poly lock nut off on the #7 intake and test for an air leak,and that does it, I would "zero lash" all the lifters/rockers on that side and then do the other side to ensure whoever installed them knew what they were doing. This is done while the engine is running for the best results - in my opinion & experience. Others adjust the lifters differently than with the engine running.
You also want to make sure you have the correct length body on the poly lock - they can be long or short. Look at the allen screw. It should not be sunk into the poly lock, nor should it stick way up and out. You want the allen screw to be somewhat flush at the top or just a thread or 2 above.
Here are a couple posts to read through that will help.
Hey Jim,
I checked # 7 cylinder today…valve cover off. Made sure it was at top dead center for that cylinder. Hooked up leak down tester. Noticed that the air was coming out around the intake pushrod hole as well. That seems odd to me…cracked head Or blown head gasket? Not losing any antifreeze or compression.
I took rocker arm off completely and no change on leak down…still at 5%.
Guess I know what my winter project is
5% leakdown is totally acceptable. In fact, it's excellent. At 20% and more you have issues. Odd you are getting air out of the pushrod hole....that leads right into the lifter valley in the block, and is not head related. Normal leakage past the rings allowing air into the crankcase and out the pushrod hole perhaps?
  • Like
Reactions: 2
Hey Jim,
Wow, I gotta say I am baffled on this one. If you had air coming from the pushrod hole, that is specific. If it were leaking past the piston/ring and out the block as geeteeohguy noted, it would be heard across any/all pushrod and oil drain holes.
And no other cylinder does this, just the #7 ?
The pushrods have no connection to the cylinders so there is no way that air would be coming out a pushrod hole. Looking at a head, the head gasket would have to break through/crack at the pushrod area to let any air past. It is possible the gasket is intact around the water passages, but somehow blown out right at that area.
Squirt some light oil into the #7 cylinder at the back wall so the oil will run down along the rings and create a seal. The compression pressure usually will go up when doing this test, but see if that changes the air sound when you apply air to the cylinder.
If the cylinder holds pressure for an extended period, then things are being sealed up and your valves/rings are in good order. Some leakage can be normal and is not an issue as the engine wears.
Bad head gaskets usually have other signs like water in the oil, oil in the water, or 2 adjacent cylinders with equally low compression/cylinder pressure. A cracked head could be cause, but most I have seen are usually between the intake/exhaust valve in the center where they are the closest.
Any gasoline smell if you check the oil?
Maybe use a bore scope and look in that cylinder.
I am running out of checks to do and would hate to see you pull the head and not find anything, but that may be the last resort just for piece of mind.
(y)
See less See more
  • Like
  • Helpful
Reactions: 3
[/QUOTE
Hi Jim,
So today with a cold engine took the spark plug out of number 7 cylinder, loosened rockers completely, sprayed some oil in there and did the leak down test. Leak down percentage was at 8%. That’s higher than the 5% I had last time. Also As you remember I was thinking I was getting air up around number 7 cylinders pushrod. Well I decided to spray some soapy water along the intake. Guess what… bubbles started coming from in between the intake and the head on number 7 cylinder with air applied to number 7 cylinder. That’s where I felt the air🙄
So Intake gasket bad.
So then I thought I would do the spraying of the oil in 7 cylinder with the engine hot.
I started the engine with the valve cover off and noticed that it was not getting any oil up through the pushrods onto the rockers. I rev the engine to about 2500 RPMs and still no oil. It wasn’t until the oil and engine got warmer (about 10-15 seconds) than the oil started coming up through the pushrods onto the rockers. That does not seem right to me.
So I did leak down on the hot engine with with rockers completely loose and got 8% leak down. Not sure why it’s higher this time. I did drive it to put fuel the day before. I did do zero lash on that cylinder. Checked the others and they were fine
I got a winter project I guess.
what’s so funny is when I drive it, the engine runs strong and smooth, you wouldn’t even know there was something wrong until you come to idle and that’s when you notice the miss.
See less See more
Hi Jim,
OK, not sure why the change in the leak down with/without oil. Intake gasket seems odd as I am trying to figure how air can get past the valve and pressurize the intake passage. Still could be a cracked head?
You should have had oil pressure the pretty much the second the engine fired. Things to consider would be clogged oil pump pick-up screen if the engine had the nylon coated cam gear and the nylon bits began to deteriorate and fall off into the oil pan - it can clog the pick-up screen, faulty/wrong oil filter, oil too thick, worn oil pump, worn bearings having too much clearance, lifter bore restrictors, pushrods with the smaller holes to hold back oil, rocker arms too loose/too tight, collapsed lifter.
Did you think to observe the pushrods to see that they were all spinning with the engine running?
Have you checked your oil pressure? New oil filter? What brand? What oil weight? Most likely if the engine has never been rebuilt, you have the factory 40 PSI oil pump. So don't expect to see 55-60 PSI. If your oil pump is failing, or not pumping enough oil from the pan, then it would not provide the needed oil pressure going to the lifters and if the lifters were not being fully oiled, this could affect the opening of the intakes and exhaust valves.
What about the wet spark plug & misfire?
Post a photo of your rocker arms/poly locks with the valve cover off. I want to see what you have. Heads should be #66?
See less See more
Thank You Jim,
The leaking was coming from the intake runner going to the intake valve not from the pushrod hole like I thought. They are close to one another so it felt like it was coming from pushrod rod hole. As far as I know the engine was rebuilt. It was stated in the description when I bought it. I don’t know if he did the whole motor or just the top end. Restoration pictures show the guy installing the cam. Supposedly it was dyno’d as well but I don’t have that paperwork.
As far as the pushrods, they are spinning when it’s running. I had checked that earlier in my investigation. It has a oil light, no gauge. So I will need to do pressure check. I will send pictures tomorrow
  • Like
Reactions: 1
Thank You Jim,
OK do what you can. I am always leary when I hear someone else rebuilt the engine because without paperwork or the name of the shop who did the work, you don't know the extent of the rebuild and what has been done and how well were things checked. You could have the wrong length pushrods. You could have a bad gasket or cracked head. You don't want to assume the worst as there are many who are honest. But honest mistakes happen and there are a lot of enthusiasts who want to assemble their own engines after the machine shop has done their work. If they do, you don't know their skill level and how meticulous they checked all their clearances.
So in all reality, it may not be a bad idea for a winter project to pull down the top end and inspect your heads, cam, lifters, measure pushrod lengths, etc. and know what exactly you have. If all looks good you can add your gaskets and button it up. But, if any issues, you will find them and go from there rather than guess or take a chance on engine damage.
If you do tear it down, make sure you take a lot of pics as you go step by step and tag/bag your removed parts so you know what/where they go back. If you are like me, you will tear it apart and not get to re-assemble for another 3-4 months and try to figure out what goes where. LOL I take a lot of pics and use a lot of zip lock bags for my parts.
(y)
See less See more
  • Like
Reactions: 1
8% leakdown is just fine. No problem with your rings or cylinder.
Hi Jim,
Here’s some photos of the engine and rockers and 6X Heads. In the 3rd photo I circled exactly where the air is leaking. Right above the number 7 cylinder intake pushrod.
I did remember when I change the oil two weeks ago all I had was the 5 quarts of the 10w-30 Lucas hot rod oil and I added that thick Lucas oil stabilizer additive to the oil. Maybe it’s too thick? I am buying straight oil and new filter for today and see if that cures the cold start up no oil problem.
The last photo is of the ad for the car. Said motor was Professionally built. Which doesn’t mean anything really. You would think if they built the motor professionally they would’ve put I new oil pump in.
View attachment 157563 View attachment 157567
(y)
Thanks Jim!
Yeah, I’m pretty meticulous when I take down an engine. Tons of pictures and lots of heavy duty zip lock bags with labels.
Im still concerned about the oil pressure.
I change oil today to straight 10w-30 and will start tomorrow with cold engine and valve covers off. I did loosen all rockers on each side, one side at a time. Then tighten until the ticking stopped and tightened the poly lock. Still have a slight tick not bad. I noticed when the rockers were loose the oil flowed very nicely after the engine was hot.
I’ve always done Chevy engines. On Pontiac with these type rockers What do you recommend for adjustment of rockers on a running engine? How many turns after the ticking stops?
I was also thinking if there was an intake leak on cylinder #7 that would cause a lean condition that could have taken out the intake valve?
I guess I’ll find out when I take it apart. Thank goodness I still have the other GTO to play with in case these one doesn’t get done before next spring. Shop and schedule times are way out on their schedules. Thanks again!
See less See more
Hi Jim,
Thanks Jim!
The attachments did not take, as I got an "Ooops!" message.
10W-30 should work and the Lucas stabilizer should not have any affect. Anytime I add anything thicker to an oil, I add it when the engine is hot and running so it flows better and then mixes thoroughly. I used the STP oil treatment in my brother's old truck which calles for 40W oil, so a can went in with the Rotella 15W-40.. The STP also has some ZDDP in it according to the label.
When you "zero lash" the rockers, you tighten slowly until the clicking stops, BUT, give it about 15-20 seconds for the lifter to adjust itself as the oil has to bleed down and find its correct level. The lifter may start ticking again, then you tighten just enough to stop the ticking and let it "normalize" again. You may only have to make 1 adjustment or it could be 3 adjustments until the ticking is gone and the valve lifter where it wants to be, Then turn 1/4 turn, tighten the st screw, and hold the set screw and with the wrench turn another 1/16 of a turn just to cinch the poly lock down.
If you have the correct poly lock length, the allen set screw should be just slightly above the nut. If it is sunk too deep, the poly lock body is too long and you could be loosing adjustment as the allen screw bottoms on the threads and not the stud. If the set screw shows a lot of thread, then the poly lock is probably too short and you are not grabbing enough of the threads inside the poly lock and you can strip out the set-screw or it can go out of adjustment because it is not getting a good enough "bite" to hold it secure on the stud.
Put a dab of white paint or something on the tops/side of each pushrod so you can see the rod spinning. Sometimes you cannot tell as some rods will spin very fast and others may just sit there and not spin and you think they look like they are. The ones that are not spinning are a problem. This can mean too tight, or see if you raise the RPM's a bit if they begin to spin. You should be able to grab the pushrod and spin it by hand with the engine running. If not, it is too tight and you want to back off the rocker arm to see if that gets it spinning.
The looser the rocker arm, the more oil will flow out the rocker arm spurt hole - this is what you want. The oil might be a little sluggish at idle RPM's, but still flow fairly well. I always go 1/4 turn on the poly lock after the clicking stops on my last adjustment. Some will say 1/2 turn or 1 full turn. Who knows? I go 1/4 turn and this has always worked, and the pushrods spins nicely and oil flows out the rockers. Too tight on that last lock down turn, 1/2 or 1 full, can compress the valve plunger too much and add too much pressure on the pushrod and the oil doesn't seem to flow as well and the pushrod labors to spin. Pushrod spinning means the valve lifter is spinning on the cam's lobe as it was designed to do or the lifter would simply sit on the cam lobe and wear the bottom of the lifter/cam lobe out - that is how they are designed.
I don't think a lean condition would damage the intake as it is the exhaust that takes all the heat as it goes out, so a lean condition would more likely do damage over a period of time and some hard running like a long pull up a mountain with a 40-foot camper behind you and a tractor trailer on your butt intimidating you to go faster (no that was not me, or was it? LOL). The soap bubbles could be simply from a bad gasket that is bad enough to allow the incoming intake charge to have enough force/pressure to allow air to escape. Bigger cams with more overlap can have revision characteristics where some of the intake charge is pushed back up into the intake during overlap - which gives the cam that nice idle sound we all want to hear.
If it is an intake problem, then there could be a number of reasons from a poor valve job on the seat, a poor cut on the valve, or a poor machining of the valve guide where it affected the valve placement or angle. So I don't think end of the world problem, might be real simple and a machining error that can be easily fixed. Hopefully you have all new stainless steel valves and the heads were not rebuilt with the stock valves as the stainless being new would give better/wider margins for a better seating/sealing. If the stock valves were used and re-ground, the margins could be thin or the valve sunk deeper into the head if the shop was trying to make what they had work because the owner did not want to spend the budget to do the job correctly. Heads could have been purchased on Craig's List already done up and at a good price and were not rebuilt well (or some scumbag pulled them off his engine because they were cracked and sold them as recently rebuilt and he was installed E-heads instead), so all kinds of scenario's.
All part of this hobby, and if you don't like working/tinkering on a car, then this hobby is not for you, OR you had better have the wallet to pay another to work/maintain your car and not squawk when the bill arrives (I don't have the wallet, just some loose change). I am not a motorcycle rider, but it has always been told me that if you own a Harley, you want to keep a tool bag with it and you own it knowing you like to adjust/work on them. So same principal.
Just keep at it and don't let it get you frustrated. It's a learning process that you can later share with others who may need your experiences.
(y)
See less See more
  • Helpful
Reactions: 1
(y)
Thank You Jim for all your help. Much appreciated. Next time I buy a classic car if the motor was rebuilt, I’m getting paperwork and parts list. That doesn’t always make up for someone’s inexperience building it, but helps to know what your working with.
That’s half the fun of owning these cars, is tinkering
btw…I keep a tool bag in the trunk😊
  • Like
Reactions: 1
Tool bag...hell I have a whole tool box complete with duct tape, bailing wire and halon fire extinguisher plus an extra coil, bulbs,
jumper cables and all kinds of tools 👍
Rectangle Automotive exterior Bumper Automotive lighting Gas
See less See more
  • Like
Reactions: 2
jumper cables and all kinds of tools 👍 View attachment 157670
Yep, always a good thing to have some tools if you can use them. It is also nice to have a few parts that you may not be able to readily get at a parts store if you get stuck out on a drive.
Ignition and fuel are the two culprits that can leave you stranded. If points, extra set of quality points/condensor, if electronic, extra module and heat sink grease. I usually save the cap/rotor/couple spark plugs from any last tune-up and toss this in the trunk. I also like to keep an extra coil-to-distributor wire if I change out wires - these have gone bad on me, but very rare. I know they worked, just time to replace them, so I hang on to them. You can source a coil easy enough.
An extra fuel filter is a good idea. If the fuel pump or anything else major goes bad, then you are most likely not going to be swapping it out on the side of the road.
With a Pontiac, I used to keep and extra starter solenoid with me. The heat can cook these and I have replaced my share in parking lots. A manual shift car is not quite a problem as you can push start the car easy enough.
I keep a tire plug set in the car - Walmart sells these. Have a set of needle nose pliers if you get a nail in the tire and have to pull it out. Then just plug the hole with the tire plug kit. Another handy item is a hose coupling kit that has several sized plastic tubes where you can cut a leaking/busted hose, insert the coupler, use the hose clamps, and be on your way - providing you have some anti-freeze in the trunk. A can of Instant Start.
And lastly - AAA or some other break-down/towing service.
See less See more
  • Like
Reactions: 2
OK, let's recap what has already been done.
1.) Changed wires, plugs, cap and rotor
2.) Compression check on All the cylinders and it’s at 180- 185 psi across all cylinders. Number 7 cylinder was 183.
3.) Changed (swapped) plugs that I know that were firing into the number 7 cylinder.
4.) Changed (swapped) wires that I knew were firing to the number 7 cylinder
5.) Engine still sounds the same with the same misfire. When I pull the plug in cylinder 7 it looks wet.
6.) Took the valve cover off and turn the engine over and watch the valves open and close. Both intake and exhaust are opening and closing properly. Valve adjustment looks good.
Single cylinder won't fire, all others do.
If bad electronic module, it would be bad and all cylinders affected.
If bad coil, it would be bad and all cylinders affected.
If bad rotor, it would affect all cylinder.
Bad cap - cracked, poor quality where brass electrode is not extended far enough to make good contact with the rotor, drilled/positioned too far away from rotor to make contact.
--When you re-attached the coil to the top of the cap, did you use the same screws? Make sure none of the screws have gone through the top of the cap and are not sticking through causing a short.
---Check the center electrode in the cap - should have a curved surface that makes contact with the rotor button and should be able to move in/out against the spring - you did replace this with a new one, right?.
Since it was running well with the old parts, install the old cap and try that.
Rotor. May be bad. Make sure the contact that connects with the center electrode in the cap is making solid contact with it. I have had to lift up on that rotor contact because it was a cheap thin strip of metal and did not have a good enough bend in it to make solid contact with the cap electrode. Some of them can have the metal contact that signals your spark to the cap's electrode be too short and the gap can be too large for the spark energy to jump it and fire the plug.
---Check the distributor shaft that the rotor sits down onto. It could be bent or have a bad bushing causing a wobble and possibly creating a large air gap that the spark can't jump - so check the distributor shaft for wiggle/play.
The Reluctor wheel that triggers the plugs to fire could be bad or grounding out. There are 8 "teeth" and do the same thing as points do in a points distributor. One of them could be bad/bent/grounding or who knows what - I know nothing about factory HEI's.
You checked the rocker arms and the valve adjustment looked good. Looking good is not the same as the adjustment is good. The valve could be hanging open just a hair and you would not be able to see that. With the engine running, "Zero Lash" number 7 cylinder to make sure the valves are fully closing. Do a forum search and you will find how to "zero lash" your lifters. Watching the valve operation could also show a lifter not working correctly. Put a white mark on each pushrod where you can see it. When the engine fires up, the pushrod should be spinning and the white mark will be easier to see. It could take a little more than idle to get it to spin, but not much. If the pushrod is not spinning, this can mean the valve lifter is not spinning on the cam lobe - which is should do. No spinning could mean a bad cam lobe.
Just an odd problem to be sure since all other cylinders are firing. Do a few more checks/tests and give us the results. (y)
Sounds like a bad relucter had the same thing happen on a 350 buick, drove it a while with a miss then later a second cylinder went to missing......put a point distributor in it and all cylinders went hitting like they were supposed too !
Yep I keep adding different things to my tool bag. I have tied if down just in case Someone does a dumb maneuver in front of me…like having to swerve. Happened to me. Had a small battery pack fly around and put an ever so small of a dent in the rear quarter panel that i could see from the outside. Body shop was able to massage it out thank goodness.
I have been spouting this same information for years to the masses on pretty much all the car forums. It goes mostly unheard and ignored. That said, I never have suffered ignition problems with all my points and condenser cars and let the guys who 'upgraded' theirs enjoy the tow truck and pissed off wife. 👍
  • Like
Reactions: 3
My tool box is bolted down 👍
  • Like
Reactions: 1
We have a Points Distributor master/Guru in our GTO group. He’s like skillful surgeon with this points distributor’s and when you have them set right they are the best option. He has all the old equipment to tune these points distributor’s. Looks like the NASA computer boards from back in the 60’s. He has said
These factory points distributors are master pieces in how they are built and work. He says hands down points distributor is far better than HEI. More times then not. HEI will fail before points distributor.
  • Like
Reactions: 1
I've said this over and over, so I'll be short. I tuned cars for a living for years. I can't count the number of cars that were towed in that did not run due to a fried module or pickup coil. From old wrecks to near new cars. I can count on one hand the number of tow in's with points simply because they were flat worn out.
HEI is maintenance free and you can get different timing curves and have rev limiters, etc. But you will not make more power with an HEI, particularly at high RPMS. Look up Lars Grimsruud's articles or watch Uncle Tony's Garage on youtube. Good stuff!
  • Like
Reactions: 1
21 - 40 of 45 Posts
