Turn up the gain on the amp in the trunk. Turn on the stereo, reach around on the outboard side, and on the front of the box you will feel a knob. You will be able to tell which was is max.ridgegoat said:OK, I'm a few days away from buying one of these bad boys, what are the must do mods that will improve the ride, easy to apply and not cost a arm and a leg. Keeping in mind the car is used as a daily driver.
I had never heard about that (stereo amp), although I read a lot of complaints about the sound system. Thanks, I'll do that first.Turn up the gain on the amp in the trunk. Turn on the stereo, reach around on the outboard side, and on the front of the box you will feel a knob. You will be able to tell which was is max.
