My 65-trunk restoration thread
1010 Views 17 Replies 6 Participants Last post by  Cased
Can someone tell me if the Ames Spare Tire Anchor bracket (part# K133K) is installed as the picture shows on the Ames Part link with the rounded arched piece going north to south? There is a little raised hump in the center of the trunk floor pan where the bracket goes, I am guessing it runs in the same direction as the bracket.
Or does the Spare Tire Anchor bracket go east to west, I didn't get a before picture of it prior to the trunk pan being replaced.
Ames Part Detail (amesperf.com)
Automotive tire Automotive lighting Hood Wood Fender
Automotive lighting Hood Grille Automotive tire Automotive tail & brake light
See less See more
2
1 - 18 of 18 Posts
My 67 had it running front to back...
Automotive tire Motor vehicle Bumper Hood Automotive exterior
Hope that helps.
See less See more
  • Like
Reactions: 2
I guess that settles that, as always you guys are most helpful.
GTOJUNIOR is how you have the blue painted jack parts accurate to only your year car, or is that standard to 64-67s?
  • Like
Reactions: 1
The OE blue differed slightly but the consensus is that the FORD V8 Blue is expectable.
With some variations depending on the home plant where your Pontiac was built.
Gas Wood Composite material Metal Machine
See less See more
  • Like
Reactions: 2
So only the jack base and jack mechanism get painted blue?
As mentioned, it depended on the assembly plant
From my Fremont 68. Three different colors.
Original appearance and restored.
Hood Automotive tire Motor vehicle Grey Trunk
Bumper Motor vehicle Tool Automotive tire Fender
Automotive tire Automotive lighting Paint Bumper Motor vehicle
Wood Gas Flooring Security Space
Office supplies Font Electric blue Writing implement Metal
See less See more
5
  • Like
Reactions: 3
Fremont seemed to have a different supplier for the bases.
For most years I've seen they had a black base.
Textile Sleeve Grey Wood T-shirt
The Jack Handle / Lug Wrench was a Robbins Egg Blue on most of the years regardless,
However, I have seen a few finished in Ford Blue, Grey, and/or Black.
I chose black for the first pic above.
Gas Wood Road surface Symbol Electric blue
Tire Wheel Automotive tire Tread Motor vehicle
I found this Krylon to be a good match.
I only sprayed the tip of this OE wrench with factory paint and you can see how close it is.
Liquid Bottle Fluid Drink Alcoholic beverage
See less See more
4
  • Like
  • Love
Reactions: 2
View attachment 164199 View attachment 164200 View attachment 164201 View attachment 164202 View attachment 164203
Interesting, my 65 is also from the Freemont assembly plant. I also noticed your Spare Tire Anchor bracket in your trunk goes side to side as opposed to the other two pics showing it going front to back of the car.
  • Wow
Reactions: 1
Maybe I will also paint the jack base black, i do think that Satin Lagoon blue is almost an exact match.
  • Like
Reactions: 1
Hmmm, looks like it could have been done either way. My thought is that it would be easier if it ran front to back as this would allow the J-bolt to pivot to the left as one would remove the spare. Seems like there would be more room to lift and slide the tire to the left, letting the J-bolt pivot and drop, as apposed to sliding forward or back. Probably a minimal difference either way.
  • Like
  • Love
Reactions: 2
Keep in mind, mine is a 68.
  • Like
Reactions: 2
Sprayed my wheel wells with the Raptor Liner Product, got to say I like the look of it, pics don't do it justice.
Azure Hood Ice cap Landscape Electric blue
Leg Automotive tire Grey Tints and shades Asphalt
Hood Automotive lighting Automotive tire Helmet Motor vehicle
See less See more
3
  • Like
Reactions: 3
Almost done...
jack stand base and mechanism are going to be
Old Ford Blue Dupli-Color Engine Enamel with Ceramic Resin DE1621
tire iron will be
Pontiac Blue Dupli-Color Engine Enamel with Ceramic Resin DE1610
Automotive tire Hood Tire Automotive lighting Motor vehicle
Automotive tire Hood Grille Automotive lighting Grey
Hood Automotive lighting Vehicle Motor vehicle Automotive exterior
See less See more
3
  • Like
  • Love
Reactions: 4
Pontiac Blue and Old Ford Blue, seeing cars out of the Freemont plant used various combinations of paint, I went with what I wanted for the final look, which won't be seen under the tire cover, haha
Azure Blue Rectangle Road surface Asphalt
See less See more
  • Like
Reactions: 1
Here's how my jack came out. The paint is part number K130A from Ames. It's "Duplicolor Engine Enamel with Ceramic."
Wood Handle Gas Composite material Machine
See less See more
  • Like
Reactions: 2
After a few hiccups the trunk restoration is complete.
See less See more
3
  • Like
  • Love
Reactions: 5
So that’s how they are supposed to look 🤔
Nice work
  • Like
Reactions: 1
1 - 18 of 18 Posts
