61 - 80 of 93 Posts
Discussion Starter #63
Last welding has been down. We are now tearing down car...getting ready for paint. The engine is also coming out for paint.
132569
Discussion Starter #65
Shucks......windshield was cracked....so we took it out.....and found a bit more rust....on it goes!
132583
132584
132585
Discussion Starter #66
A HUGE day today.....frame and body separated...all went well. Frame is nice. All new bushings going in everywhere!
132593
132594
132595
132596
Discussion Starter #69
Things are moving along. Engine is being readied for paint. Unfortunately 1 manifold bolt broke and we are uable to budge whats left of it. We have soaked it in PB blaster, heated it, welded a couple of nuts on it....just wont budge.
I am installing RamAir manifolds.....the bolt that wont budge is on the left forward exhaust...right bolt. If we are unable to get it out and just cut it of...will that be enough to hold the Ram Air manifolds tight enough with no leaks? Any ideas appreciated...tahnks.
132653
I'd take it to a machine shop and have them remove it. Not hard to do but can be a problem if not done right. You may have to supply the correct tap to clean up the threads afterwards.
Discussion Starter #80
Front end is done. All new brake and fuel lines installed. Engine is soon ready to be mounted!
132977
132978
132979
132980
61 - 80 of 93 Posts
