81 - 93 of 93 Posts
I'd flip the sway bar link bolt with the threads to the bottom. As soon as you put any weight on the frame the link bolt will be rubbing on some other component. Do not trim the bolt length until full weight is on the frame.
Discussion Starter #83
Sway bar bolts flipped. Project is moving along....new disc brakes up front....new gas tank...new exhaust.......
133188
133189
Looks great, sounds even better. But I have to ask, why go through all the work you are doing and the floor pans have not been cleaned up and undercoated/painted?
Discussion Starter #86
Of course the floor pans will be cleaned up an`all...but that comes a bit later.
We took the first drive in car today!....yeye!
I am having a bit of trouble with lock up on the rear wheels with the new brake system......is there any way to adjust the disc/drum prop valve? Thanks
Discussion Starter #87
My Goat, Valentine, is almost all back together again. She was picked up today on her way to be painted! Yey!
133241
Discussion Starter #88
A small update...the Goat is in the paint booth! Yeye! The color in the pictures is not the final color...just pre-color. Verdoro Green Metallic goes on today! Getting close to completion now!
133587
133588
81 - 93 of 93 Posts
