1 - 12 of 12 Posts
I know no one can really help me out with this. But i just got back from the freakin track and i am fed up. It was the nicest track around and that still didnt matter. i have the pedders drag pack suspension ( springs 5/16 raise, big bore shocks, camber kit, bushing, ect) 18/ 9.5s in the rear with a 275 bfgroodrich g-force sport tires with less than 4000 miles. 160 thermostat, blackwing filter, pacsetter LT without cats, SF h pipe, and slp resonators, with the slp 455 tune. B&m short throw toooo. and lowered tire pressure.
My fastest freaking time was 9.10 at 80.25.
You know me be a bad driver is one thing cause my car is a 6 speed, but am i wrong in thinking i am about a full second off from were i "should" be? maybe im asking to much. i mean can a good driver really make a full second diff?
The driver mod is the most important one.
I don't think you understand how much of good track times really is the driver. We have all seen and heard of high 12 sec stock GTOs. I ran a 9.18 1/8 my second run ever in my bone stock 05 M6 with full tire pressure and all. That is still terrible but it shows that your 9.10 with your listed mods is definately due to driving skill. It just takes alot of practice and adjustment in driving technique it really is an art. Just stick with it keep practicing and asking for tips at the track and on here and most of all have fun! I am very far from a professional and I am still trying to perfect the art myself but that is just my .02 cents.
I've run guys in identical cars and beat them by a 1/2 second or so. I'm talking in the 1/4 mile, not the 1/8, so there is a bit of time made up on the big end.
What were your 60' times?? Also what rpms did you shift at??
The GTO's tach is slow. If you shifted at redline, you were probably hitting the rev limiter. you need to pull first at 6100-6200. Second needs to be pulled at 6250-6350. Anything higher and you've lost time.
The launch in a GTO is tricky too. There is a sweet spot. If you miss it too low you bog and kill the run. If you miss it too high you spin too much and kill the run and can get wheel hop and break things. Things like how you release the clutch are very important.
A full second is not out of the question.
I had a friend in Pittsburgh that had a 2000 Camaro SS. He spent a bunch of money on it to get it to go fast. He got a best of 13.012 and couldn't break into the 12's with the car. He sold it to another friend of mine down here in Florida. This guy has a driveway that is more than a 1/4 mile long and he practices in his driveway a bunch. He can get the Camaro into the 11's. Same car same tires and similar conditions, just different drivers.
Thanks alot guys for the advice, thats the exact things i wanted to hear. I have thought about it alot and i realized that a full second isnt alot of time, unless your at the track. I mean every little thing matters at the track. So i just need to get better
I guess theres no where to go but up.
reaction .290
60' 2.207
The only thing the reaction time is oing to show is how long it took for you to trip the beam from the time the light turned green. Anything below .100 is good. I strive to get below .010 and usually make a .050 or better. That is something that takes practice. You need several runs to figure your cars roll-out time. That's the delay in the drivetrain between when you release the brakes or cutch and the wheels actully turn forward.
A 2.20 60' is a bit long. Do you remember if you were spinning or not???
Also what tire pressure did you have your tires at??
What RPMS were you at for launch????
M6 or A4???
Discussion Starter #10
At first tire pressure was like 42 and i about wrecked. then we lowered it to 32 i think. maybe it was all the way down to 22.
I was launching around 2000, i have a buddy with a 2001 zo6 and thats wat he was launching and he was running freaking 8.1's completly stock.
And i did spin, but not as bad as i did with the stock tires. i was kinda scared after i about wrecked into the wall.
Oh yea and its a m6, and i know that hurts.
You should have the tire pressure at 42 for the fronts. 22 is about right for the rears. If you go too low they tend to cup slightly and you lose traction. I found 24-26 to be a sweet spot on the stock tires. That's something you will need to play around with on your car.
2000 is a good starting point. If you spin too much drop the rpms down a bit or adjust the tires. Don't do both, because you won't know what is working and what isn't. Only make one change at a time so you know the results.
I just about always had good luck with an 1800-2000 launch with a fairly quick lift of the clutch and a progressive squeeze on the gas, don't just mash the pedal. Work into the pedal and have it all the way down at about 3500 to 4000 rpms.
If the track was extra sticky I would increase my launch rpms till about 2300.
To practice, find a nice dry empty street or parking lot and try launching. You shouldn't see more than about 10 feet of solid black marks if you have your launch right.
With your tires, you should be able to cut a mid to upper 1.9's 60'. That .25 that you shave off the 60' will net about .4 in the 1/8 mile.
You need to remeber the Z06 is about 600lbs lighter than your car. I'm not sure what kind of power you are putting to the ground, my guess is 365-37o rwhp, if he is stock he is putting 330-340 to the ground from an 01. You would need to be putting 400 to the ground to match him, maybe more since it's only an 1/8 mile race and weight is a killer in the short run.
Get the launch right and when you are comfortable there work on keeping the car perfectly straight and shifting at the sweet spots. Work on one thing at a time. The launch will bring you the biggest gains.
Discussion Starter #12
Thanks alot fergy, i have alot i need to work on i guess. But you gave me some perfect things to work on. Ill be back with more info after the weekend on what i can get it down to
1 - 12 of 12 Posts
