I have seen the varying thoughts on how much to add and where to fill, so I thought I would just add my results. I jacked my car WAY up on the driver's side, front and rear, then opened the drain plug. once it started draining, I then opened the fill plug on the driver's side. After draining, I measured what came out, and it was right around 4.6 liters. I then pumped back in that same amount of Royal Purple Synchromax. I say jack the car WAY up, as I had it start leaking out of the fill port at around 4 liters, and had to jack it up higher.
Car shifts a TON better now.
Gary
Gary
