1 - 9 of 9 Posts
I dropped the gas tank on my 68 GTO in order to replace the sending unit and upon dropping it discovered a 3/4 inch rubber hose at the front passenger top side of the tank...is this just a vent of some sort? I had no idea it was there until I dropped the tank and I dont know if it had been connected to something, although it doesnt appear to have had a clamp or fitting of any sort. Would like to know before putting the tank back in and finding out I should have done something with it. Thanks for all replies!!
John
If I had to guess, it was someone’s previous attempt at a return line. Then, someone came along later and did it right with a return on the sending unit and abandoned the other one.
It is a vent hose. There was a little filter thingy in the open end. Those usually disintegrate away as the years pass.
Sent from my SM-G930V using Tapatalk
Thanks that's what I thought. After I spent additional time under the car I see there is a little metal "bracket" that the hose fits into and is held somewhat in place. All is good and the fuel gauge is working, so now I can literally watch the fuel consumption as I am tooling down the highway!
You can purchase the filter end that goes on the hose from several of the Pontiac parts suppliers.
That vent came with my new gas tank and my old tank had the same and was just a piece of hose pointing upward. That looked dangerous to me and figured since it is vented back at the fill pipe, why do I need it so I just plugged it off. Anyone know if this is not ok to do?
I didn't see anything other then this illustration in the service manual.
If it were me I would leave it as factory and just be sure it has the Restricter and clamp in place.
Kind of disappointed at what I got from Inline Tube for about $18. A standard piece of hose with a little 3/4" piece of white foam stuffed in one end and a regular office staple where I guess it's supposed to hold the foam in place. I blew into one end of it and the foam came flying out the other!
1 - 9 of 9 Posts
