First let me say thanks for having a forum for help. I have an 04 GTO. The emergency flashers wont work. Turn signals are fine. Any ideas on what is going on?
Do the Indicator Lights work in the Instrument Cluster? Does the Hazard Indicator Light work on the Hazard Switch?
Check the HAZARD LAMPS Fuse 15A in the Instrument Panel Fuse Block. Also, check the wiring harness behind the glove box for chaffing.
Could also be a BCM Problem or a wiring problem.
Larry
Schematic attached
