My 2000 Bonneville's oil pressure gauge is all the way up to 120. I had my oil changed around 3 weeks ago. Does anyone know why this would happen? Thanks in advance.
the only reason this is so urgent is because i need to get to work tomorrow. If something is unplugged, i can still drive it right?
if something is unplugged yeah you can drive it. you may check to see if they put too much oil in the car. but there is a possablity that the senting unit for your oil oressure gauge is going bad too.
Not sure about Bonneville's, but I know that on a C5 Corvette, when the oil pressure sending unit goes bad, the oil pressure pegs high. I suspect that is your problem. :cheers
