1 - 20 of 27 Posts
So I am having trouble figuring out how to use the comp calculator:confused. could use some help. I have a 67 gto original 400 has not been decked before and will be getting its 1st bore at 0.30. current 670 heads are 75cc.. if you need more info let me know. I did not know what the gasket bore is off hand. The machinist took the liberty of ordering some flat top pistons he mentioned in a prior conversation once I gave him the go ahead to do the bore.He believes it may have to be decked also removing #s off my block.The pistons below is what butler recommended with the info I gave them. And the book pic is what the machinist ordered. what do you guys think? he is aware of the 40-45 quench. by the way 068 cam.
Looks like the same type pistons - the "D" dish with 17 cc's. KB346 pistons, not the flat top at the top of the page - its for the 151 4-cyl engine.
Plugging in the numbers at the Wallace site, I come up with 9.17 compression and plugged in 4.30" for the head gasket. I also used the .041" head gasket thickness and 000 on the deck clearance as this would be the same as .041" quench distance. If you went for a .045" quench distance, compression on the calculator is then 9.09.
He may or may not measure for the .040" - .045" quench, but he also might. This is something you need to ask. Simply tell him you rather not cut the deck if possible and use the thinner Cometic head gaskets (which are as thin as .027" and also come in other thicknesses) if this would work instead. They can also be closer to the actual overbore of the cylinder which will add cc's compared to a larger bore size like the Felpro. Cometic gaskets are $100 each, but probably the best. So it may be cheaper to mill the deck and go with Felpro gaskets that come in the engine gasket rebuild kit. Again, this is something to discuss with your builder and voice your concerns and then listen to what he says - he may have a preference or none at all.
Here is what I have saved on head gaskets gathered from the web:
Fel-Pro introduced PN-8518 for the Pontiac V-8 during the 1970s. Containing a bore diameter of 4.3 inches and a preflattened thickness of .041 inch, it’s a stock-replacement design that’s compatible with most Pontiac blocks. an affordable choice for any stock rebuild, and even performance applications with a compression ratio up to 10.5:1, or slightly more.
A second Pontiac offering appeared in the Fel-Pro catalog during the early 1980s. PN-1016 is specially designed for high-performance applications with high compression and/or combustion pressure. Constructed of a Teflon-coated solid-steel core, it features stainlesssteel combustion armor and a wire ring combustion seal for maximum combustion containment. It contains a chamfered bore diameter or 4.3 inches and pre-compressed thickness of .039 inch. it’s a good choice for naturally aspirated engines with a maximum compression ratio of 12:1 and/ or mildly boosted applications.
Cometic is the only company that presently produces MLS cylinder head gaskets for the Pontiac V-8. Bore diameters range from 3.75 to more than 4.4 inches and standard compressed thickness measures .040 inch. Any other bore diameter and thickness from about .020 to .120 inch is available on a customorder basis. Suitable for stock rebuilds and max-performance applications.
Each .010-inch difference of head gasket thickness alters the static compression ratio by about .15:1.
I would not use those "Hypercast" pistons under any circumstances. If they are used, you must have a really big top ring gap. There have been lots of wiped out engines because of using those pistons & a gap that was too small.
Some guys use the cheaper SP L2262F forged pistons & have a dish machined into 'em. But if your budget will stand it, I'd recommend Auto Tec custom pistons. They can position the pins so that you can get zero deck height, without cutting extra material off the block.
Other advantages are lighter weight & floating pins. Only negative I can think of is price. Will probably cost between $500 & $600.
So Forgot to mention I am looking to run on pump gas 91-93 octane here. I would like to get the most compression that is safe. What do you guys think that would be? And is that possible w/o decking the block dont want to run no race gas no additives. It will be a cruiser and just get on it now and then. No track. I have only put 3000 miles in 10 yrs. May be less now that I got a travel trailer. BigD you still down on those pistons with that info?
bigD: "I would not use those "Hypercast" pistons under any circumstances. If they are used, you must have a really big top ring gap. There have been lots of wiped out engines because of using those pistons & a gap that was too small."
PJ: Hold on, don't throw the baby out with the bath water. You might not use them, but Butler did not have a problem recommending them and I'm sure they use them or they would not have recommended them.
You are correct with regards to the ring gaps BUT, most piston manufacturers recommended ring gaps with their pistons based on piston material & use. Even the ring gaps used on the "better" forged pistons vary based on things like power adders. My machinist told me that some of these engines he builds for big shots of nitrous look like oil burners when running because the ring gaps have to be so wide. Once they hit the nitrous, the heat takes over and expands the pistons and closes the gaps to where they need to be - if not, they would but and break rings & pistons.
The manufacturer of my forged pistons has a recommended gap when using nitrous. Why? Same as the hypereutectic pistons, heat. Nitrous generates more heat and if the rings gap is not spaced wider, they too will butt and bust the ring land or piston top off. So I don't think it fair, or justified, to slam the hypereutectic pistons and get RMTZ67 all concerned when the piston is actually not the problem, but rather the heat of expansion. Ring gaps need to be set according to the piston manufacturer and not by the factory service manual unless you are using a like material piston.
This is from another forum and describes the problem to a "T":
"I've beat the snout outta hypereutectic pistons- massive nitrous hits, vicious over-revving, and now 2 supercharged engines.
99% of the complaints about hypereutectic pistons "shattering", in my opinion, come from improper setup/machining. Hypereutectis want tolerances that are very different from either a forged or a standard cast piston. Recommended ring gaps are usually much wider on a hypereutectic because the material and the design of the piston throws a LOT of heat at the rings. If you don't follow recommendations you'll butt the ring ends together (especially if you encounter detonation), instantly "shattering" the piston. Usually involving ripping the ringland above the top ring off the piston, and instantly destroying the engine.
Also, Hypereutectis want a bore-to-piston clearance much tighter than a typical forged piston- much more like a regular cast piston. In the range of .0015-.0020 for a N/A application, .0020-.0025 for a nitroused or blower application. Anything wider and you're just beating up the piston by letting it rock in it's bore too much.
I am currently using KB Hypereutectic pistons in my 383 blower motor. Top ring gap is a MASSIVE .032". Almost TWICE what a typical cast or forged piston would require. And exactly what KB recommends for my application. Works fantastic. I have personally, in the past, made the mistake of gapping too tight thinking I knew better than the manufacturer (did them at .025). I was wrong. First time I hit detonation I butted the ring ends and ripped the top ringlands off the pistons, destroying the engine.
Now that I've got the gaps set right I have encountered similar situations with detonation but the pistons held up just fine this time. Do it EXACTLY like they tell you to and you can push Hypereutectics a LONG LONG way. They aren't made of glass. They're tough little suckers.
I am NOT recommending that you throw hypereutectic pistons into your next boosted/nitroused motor. Forged pistons will still take more punishment, in my opinion. But ANY piston will eventually fail if you run it in detonation. Some just take longer to fail than others."
Followed by: "I agree with everything that you said, but remember that you're running KB hyper... pistons, which are much better then most."
PJ: Forged have their place, cast has their place, and hypereutectic has its place. Each choice requires that the manufacturers specs be followed by the machinist and/or the engine assembler/builder. Used the hypereutectic in my brother's engine and still going strong. I would not have a problem using them in one of my engines as a replacement for cast pistons and if costs were a factor. I don't think I would use them with nitrous either. But otherwise, I would not have a problem. As stated above, detonation will kill them or any piston if not checked. With the lower 9.0 compression, I don't think detonation should be a problem unless the wrong cam is selected that builds more cylinder pressure & thus more dynamic compression that could lead to detonation.
To each, his own.
My opinion is: Why take a chance, when there are plenty of stronger, lighter forged pistons available ?
Only reason I can think of is if using them will save you hundreds of dollars, and you're on a very tight budget.
We all have our opinions. This is mine, about hypercast pistons. :)
PONTIAC ZONE TECH FORUMS - View Single Post - What pistons to buy??
Agreed, we all have our opinions - and diverse opinions can only help some in asking more questions, doing more research, or making better informed choices. You would not run with the hyper's whereas I would and I would not run a roller cam without the lifter brace whereas you would.
The post you linked to was put up in 2005. It is now 13 years later. Improvements, or even better awareness, of setting up these pistons can only have evolved since 2005.
From what I gathered, since these pistons are a casting, many were setting ring tolerances according to what they were familiar with and would have used for the factory or replacement cast piston - not the hypereutectic pistons. They are of a different composition just as forged pistons can be made of different materials & mixtures of alloys and ring placement was made higher putting them into more heat.
In my opinion, they have features that are better than cast WHEN used in a stock or mild performance engine not using nitrous or supercharging.
Hypereutectic pistons are simply a stronger type of alloy with a higher silicon content. Silicon doesn't expand so you can run tighter clearances with these pistons than with others, which helps seal-in the combustion pressure, plus the alloy used in these types of pistons is better than what other cast pistons have so they are stronger than any typical cast piston, but they are still cast pistons, which have limitations to what kinds of stresses and such they can be put through.
KB Pistons can be installed tighter than other performance pistons. A close fitting piston rocks less, supports the rings better, and seals the engine for maximum power.
The Keith Black pistons unique thermal conductivity, ring location and varied end use requires special attention be paid to top ring end gap. KB pistons make more HP by reflecting heat energy back into the combustion process and, as a result, the top ring runs hotter and requires additional end clearance. Increasing ring end gap does not affect performance or oil control because normal end gaps are realized at operating temperatures. Failure to provide sufficient top ring end gap will cause a portion of the top ring land to break as the ring ends butt and lock tight in the cylinder. The broken piece may cause further piston or engine damage.
Hypereutectic piston engines will require 2-4 degrees less total ignition timing. One key to top performance is to have all cylinders igniting and producing a like flame travel that produces the same timing numbers. Equal air flow, fuel mix, quench, chamber temperature, swirl, and compression at each cylinder work to this end.
HYper's had some set-backs when they first hit the market and from what I have read all over the net is it came from improper ring gaps and taking into account that they were said to be stronger than cast and guys running power adders which further aggravated the ring gap problem - suffice to say that the pistons were not the true problem, but the expansion found in the rings at the higher temps due to the higher location of the top ring land which required wider ring gaps. Once the hyper's, like any engine product, gets tarnished or is given a bad review, the stigma of a bad product seems to hang over them like a cloud even though it is a good product when used as intended and manufacturer specs are adhered to. Finding blogs, threads, & forums that are current and not 15 years old seem to put hypereutectic pistons in a more favorable light. :yesnod:
Hypercast pistons
Well thanks BigD and pontiacJim for your input. Varying opinions is expected in most any question brought to the table. That being said everyone should do there research and take in to account others opinions. When I started out this venture I was expecting to replace a cam and has grown to a entirely different scope. So to say it was unexpected would not be the truth. But its been a long time since I have been this deep into a engine so trying to refresh myself and learn a few things along the way.This forum is indeed a life saver. So thanks to all those who help the least of us out. If the plan was to completely go thru this engine I would have saved up a fortune. But since this build was unexpected I have to make due. Hyper pistons, use my current rods with arp bolts.Refresh my 067 heads. Well you get the picture. Like you said PontiacJim Butler recommending them is saying something. I doubt they would sell them if they did'nt have there place. The machine shop and owner that recommended the pistons has been in business here for over 40 years. "BUT" they need to know your needs and wants for your engine. With what I will use my car for I could probably use coffee cans for pistons lol. Car shows and the occasional sunday cruise. Dont get me wrong I like spinning those wheels like everyone else but only on occasion. So thanks for your input guys. And I am sure this will not be the last question I ask. RMTZ67
You're taking the right approach by taking your time and doing the research. Like every other topic on the internet you'll find opinions and ideas all over the map. It's a great source of information but one must dig deeper into all of it and consider background and the logic behind what people have to say in order to arrive at the real truth. Personal experience and even personal biases do play a part. I ran a solid roller on the street and on some long distances for more than 5 years with no lifter bore brace and it wasn't an issue. However the cam profile was not super aggressive and didn't need monster springs to keep it under control. It was a rocker arm failure that sidelined it, and to be truthful that was partially my fault for failing to recognize some warning signs. I'm going with a more aggressive cam this time that yields more lift and about 20 degrees more duration even after 'dropping back' to 1.5 rockers - and using a lifter bore brace. I'm also using stainless steel full roller rockers in place of aluminum ones. I went through one of those long "multiple opinion" challenges with regard to the lifters and oiling not too far back. I'm using Crower "HIPPO" (high pressure pin oiling option) lifters and during mockup realized that they would not be getting oil whenever they were at zero lift on the cam base circle. The question was, "will that be an issue"? Opinions were everywhere, even from different people I talked to at Crower over a period of several weeks. Ultimately I opted to provide full time oiling, and my first 'solution' of modifying the lifters themselves left me with a brand new set of $800 lifters that I had essentially ruined. (My solution 'worked' at zero lift, but also caused oil leakage at max lift - doh!). I have a second set of new lifters and a solution now that will work as intended, but it was scary because it involved modifying the lifter bores in my original to the car numbers matching and therefore irreplaceable at any price block. Gulp. I used a small rotary tool to cut some grooves at the bottom of the lifter bore oil feed holes to extend them 'downward' so that they now feed oil to the lifter oil bands at zero lift, but also don't leak pressure 'anywhere'. I had to really think about that one long and hard before I picked up that tool, let me tell you!
Anyway, you're doing the right thing. Take your time and understand not only what you're doing but why you're doing it, and everything that can logically result from the choices you make. It all eventually makes sense.
The thing that concerns me the most is that the machinist said that decking will remove the numbers on the block. Only Chevrolets have that issue, due to engine number and VIN number location on the pad on top of the deck. Pontiacs have the number on the front of the block, below the passenger cylinder head, next to the timing cover. In an area that would never get machined or milled in any way. In my experience, Chevy-savvy machinists are NOT then ones to use when doing a Pontiac Strato-Streak V8!! YMMV.........but you've been warned.
Deck #s
Well on there behalf he did tell me the #'s there were not important. It's me that needs a refresher course:blush: where the important #'s are.:blush:
Discussion Starter #12
pontiac builders
Well there are not many if any pontiac only builders around anymore. And some like CVMS Also don't know what they are doing. I am sure you are aware of Goat Ropers story. So looks like its a gamble no matter who or where you take it . I had another builder build my 350 4 bolt on my Z28 and when I did the break in it went to s#!*. Was it my fault? I have broke several motors without issues. I took it to another builder to diagnose why I could not get it to run smooth before I knew there was a problem. He stated he believed the lifters were probably set too tight. Maybe you could just offer some tips as what to look for. They are doing the machining and I will be putting it together. A refresher course of sorts. Along with rockys how to book. I could buy several blocks and try 3-4 times for a good one and still have thousands left over for what Butler or any of the others charge.
It is not very difficult if you take your time and understand what it is you are doing. Rocky's book is pretty good with detailed pics. You will need tools, and the cost of purchase might not be as cost effective as having your machine shop assemble the shortblock (piston, rings, rods, crank, cam bearings, main & rod bearings, rear main seal) and you install the oil pump, oil pump rod, pan, cam/lifters, timing items, top end, etc..
A budget build is fine and you know what to expect and don't plan on racing it.
Hyper's would be my choice as has been suggested. Having the cast rods magnafluxed, resized, and ARP rod bolts installed should be fine for a street engine. I see Spotts Performance offers reconditioning/resizing of cast rods with the ARP rod bolts for $200. A set of 8 used rods is $50 more. So your shop should be close to the $200 ballpark in reconditioning your rods with the ARP rod bolts - unless they add polishing the side beams and shot peening, and then you would probably be in the territory of new I-beam rods. The forged I-beam rods look to be about $319.00 plus shipping.
With new pistons, you will generally get the engine balanced. On averaged this seems to run about $200. This will include pistons/pins, rings, rods, crank, harmonic balancer, and flywheel. You will want to get a NEW balancer. I would not use the old original as the rubber typically deteriorates and timing can be off or catastrophic failure can occur. Yours is a "2 piece" on the 1967 and they go for around $170 vs $50 for the one piece 1968 and up balancer. They cannot be swapped as your timing chain cover is set-up for the '67 2-pc and the balancer diameter is a different size and your timing cover degree scale is designed for that balancer. Not saying you cannot use yours, but I don't know as I would trust it if it is the original.
Additional block work would be the installation of threaded plugs in the front of the block's oil galley holes. These are freeze/cup plugs that get staked. They can work loose and it is best to simply tap the hole and install threaded plugs. Many shops do this automatically. Should not be a big charge to do this. I would let them install the freeze plugs as well because they have the tools that make it much easier & quicker for them to install.
So just a few things to think about. I always write up a "plan" or "outline" on what parts I need and what the shop will do/assemble and what I am going to do. :thumbsup:
Discussion Starter #14 (Edited)
Engine build
So just a few things to think about. I always write up a "plan" or "outline" on what parts I need and what the shop will do/assemble and what I am going to do. :thumbsup:[/QUOTE
So The machine shop will magnaflux and resize rods add arp bolts install pistons get rings and bearings. clean up minor scratches on the crank. get main bearings. I bought a freeze block kit with oil galley threaded plugs which they will install,They will install cam bearings also. my heads were freshened up. I must check and make sure the threaded plugs were installed. would there be a concern if they were not and had to be done after the block has been cleaned already? they said the lead time to compete the short block would have a longer lead time but they would do it.I feel confident in just putting the engine back together once the other stuff is done. If the rings have to be resized I will have them do it and install them on the pistons. Here's a couple of questions. I bought a 80lb oil pump planning on putting it in my some what worn engine after a cam install only. But now with new bearings and all I am guessing I should get a stock type oil pump? Also do they make a balancer with total timing marks on them already? Thanks for all your input. RMTZ67
Paul Carter of Koerner Racing Engines in Tuscon, AZ has been around a long time, and is a Pontiac specialist. He gets nothing but rave reviews on the PY/AMES Pontiac forums. That said, I have not used his services, so cannot give you a first-person review. But if I were in your shoes, and as close as you are to AZ, I would at least call him and have a talk. He's a great guy and a huge help on the other forum. His modest 389-400 builds have produced very respectable power AND reliability. FWIW....
AS a P.S: and disclaimer, I recommended CVMS to Goat Roper, when their rep was still stellar before Jim had vision issues. I still feel crappy about it.
The shop will tap the oil plugs. They will most likely just wipe down/clean or blow out any small particles. What you do want to check for is that the plug is not screwed in all the way. If it goes in too far, it can restrict or close off the oil supply to the lifters. Also make sure the hidden plug behind the freeze plug was installed at the back of the engine. You should be able to shine a flashlight down the distributor hole and see it, but you could inquire by asking if the pipe plug at the rear of the oil galley was the same size as the ones they installed in front - put it in a question like that and it should not insult them because you are just curious. :thumbsup:
I would not use the 80 lb oil pump - my opinion is it is really too much unless you open up the bearing clearances or were spinning your engine up past 6,000 RPM on a regular basis. The 60 psi pump would be better. The Mellings pump is good, but if you can afford it, the Butler blueprinted 60 psi pump is the way to go. https://butlerperformance.com/i-24453827-butler-performance-pro-60psi-oil-pump-w-pickup-screen-bpi-m54ds-pro.html
Now if you feel this too much, buy the Mellings 60PSI pump and add the heavier oil pump plate with anti-cavitation grooves. It comes with the longer bolts for installation. I purchased this one for $30, but then decided to go with the Butler 60 PSI pump which they did not have at the time and only offered in the 80 PSI. I did inquire about using the blueprinted 80 PSI pump in my 455 build at the time and Butler said the Mellings 60 PSI pump would work just fine. So check this out: https://www.tinindianperformance.com/pontiac-oil-pump-plate/
You also want a new hardened oil pump shaft like this one: https://www.summitracing.com/parts/mel-is-54a/applications/make/pontiac?prefilter=1
I don't know if they make an early balancer with the timing marks on it like the '68 and later balancer that is available. Can't say as I have seen one. Adding a timing tape may be your only option on that one.
What Jim said on the oil pump. And pretty much everything else. 80 PSI pumps are good for spun bearings and oil leaks on stock clearanced engines, IME.
Hello everyone! I'm new to this forum.
I'm in the middle of a rebuild but not on a GTO but a Trans Am. Hopefully, I could share and receive some advice as well on the drive train side.
The engine is a 400 manufactured in 73.
I'm in the aftermarket selection process with replacing the old pistons ( which were forged from a previous rebuild about 25 years ago or so ) and replacing them with possibly 4032 forged JE SRP Pistons. Also changing out the rods from the stock to 4340 Forged Eagle H-beam.
My intended use is street/strip with some hard driving and once in a blue moon at the drag street.
I believe this is a strong enough set up, but I would like know if there are any disadvantages running this combo in daily driving. My daily driving consists of going to weekly car shows. I have a lot of country roads and highways with some city driving.
I have read somewhere that these pistons are noisy??
Reusing my original cast crank and the builder is beefing up my heads. He produced a sheet which shows our intended CR is in the 9.1 or bit higher. Cam is 216/228 @ 50, .454/.480, 112 LSA . .
We welcome anyone with a Pontiac and like it best when it still is powered by a Pontiac engine. (y)
Your combo is fine for a street build. Build the engine for torque not HP. The forged pistons should be ordered once your engine builder knows what the bore size is, ie needs to be bored .030", .040", or .060". Then once he has pistons in hand, he will bore the cylinders close to the needed bore size and then finish the cylinders by honing to get the manufacturer's recommended clearances. These would be based on an engine using gas, and no power adders like nitrous. Power adders can increase heat, which increases piston expansion, which then requires additional piston-to-cylinder wall clearances. If you do not clearance for such power adders, then when the piston expands you can scour the cylinder walls, butt piston rings at the gap and break rings/pistons, or lock up a piston in the cylinder. BUT, I assume you are not using a power adder, but wanted to cover this incase you were thinking of it.
Forged pistons generally need more piston-to-cylinder wall clearances because they expand more than a cast or hypereutectic piston will. So you hear the stories of forged pistons that will "rattle" a little when cold and goes away when the engine warms up. It also depends on the type of forging as some expand less and this is why your machine shop will follow the manufacturer's clearances for that piston type. I would not be too concerned. Forged pistons are the way to go as they can also better handle any detonation should you encounter any.
With 9.1, or slightly higher, you should not have any issues with detonation and pump gas. 9.0 is the target number, but the range can be as high as 9.5 if the engine is built well with matched parts.
Key point here is quench distance. Your machine shop should be very familiar with this. You want to have a quench ( that little space between the top of the piston and flat area on the bottom of the head around the combustion chamber) distance between .040"-.045". This really helps with preventing detonation by forcing the gas mixture into the chamber for a more complete burn, and cools (thus the word "quench") the gas mixture. Your machinist can measure the deck height and order a custom pin height for the piston to get the top of the piston even with the deck, called zero deck, or just slightly lower down in the hole like .005". Then you can use a Felpro head gasket having a compressed height of .040" to give you the .040"-.045" quench.
The deck can also be milled down to get the piston height you need, but I personally rather not while others will have this done to get the needed deck height, square up the block, or clean up the deck surface.
Most Pontiac pistons are .015"-.020" down in the bore. So option #2, what I did, was purchase a set of Cometic brand head gaskets .027" thick. My .020" down in the hole pistons with the .027" head gaskets gives me .047" of quench - close enough to .045". Cometic's are not inexpensive. They also come in other thicknesses and different bore sizes.
Forged rods are what you want to replace the factory cast rods. Your options are the H-beam or the I-beam, bith have the better 7/16" bolts. The I-beam is more like factory in look, but is forged and has the better rod bolts Seen here - https://butlerperformance.com/i-31643273-eagle-5140-forged-6-625-i-beam-rods-arp-8740-bolts-press-fit-set-8.html?ref=category:1234812 The H-beam comes in 2 flavors, a press-fit piston pin or bushed for floating piston pins. So you want to match the rod pin style to the forged piston recommendation - press fit or bushed fit for floating pins. Press fit is fine for a street engine. They are more money and not sure any real advantage for a street engine. Here is the H-Beam bushed as an example - https://butlerperformance.com/i-31643357-eagle-4340-forged-h-beam-rod-6-625-2-250-pontiac-rj-bushed.html?ref=category:1234853
You will need to have the crank assembly balanced. Get a new harmonic balancer to replace the old original - cheap enough, cheap insurance.
The Pontiac crank has small serrations at the rear main seal area to help lubricate the old style rope rear main seals. If you use a Viton seal, this needs to be polished so the serrations do not dig into the Viton seal and damage it over time. Many suggest the Best brand graphite rope seal and seem to have less problems with rear main leaks. I have used the BOP brand Viton on my last 400 build with no issues after 25,000 miles. But other have issues from day 1. So the rope seal may be a better choice, but that is between you and your machinist. https://butlerperformance.com/i-24452895-best-gasket-braided-teflon-graphite-rope-seal-for-326-400-bga-6380x.html?ref=category:1234758
Cam looks to be a good choice for street/daily driver with the 112 LSA. Get a good 3-angle valve job.
1 - 20 of 27 Posts
