1 - 13 of 13 Posts
I am getting 15x7 Ralley 1 rims for the GTO so it will accommodate front disc brakes. Now for the tires. I don't want them to rub so what would be the largest tire I could get? I was thinking of getting 225 70 R15s? Would that be a good choice? Seems like I saw that it was somewhere on the forum here. Ralley 1s are from National Parts Depo.:patriot:
good question. Im curious to see what size 15" tires '65 owners are running. ive got 215 65 R15 T/A radials on 15x7 torque thrust mags with a GM single piston disc brake kit. when the outside edge of the tire passes by the front lip of the fender, you can barely get a matchbook between the tire n fender. kinda too close for comfort.
Tire Rub
Well I went ahead with the tire purchase and sure enough the 225-70-R15s have a rub when I make a sharp turn. It doesn't seem to be that bad but I cant have a rub. So, it's either new fronts or some sort of spacer I'm told I could try. Too bad though I really liked the look of the tires. Rear of course is not a problem...just the front.:cuss:
Banned
The recommended tire size is 225/60-15 the 225/70 is a little bit taller.
I just ordered a set of 225/70-15 redlines for my 67 because I couldn't find redlines in 225/60.
I have 235/70-15s on it right now but the rear passenger side rubs on the fenderwell with 4 people in the car.
The front tires also rub slightly going onto off camber aprons but I can avoid the rubbing by swinging out wide and going onto them at a straighter angle.
no spacer. 60s on the front will give you enough clearance from the bottom lip of the fender with 15x7 wheels.
I have 215x70x15's on my '65. Coker redlines. If you contact Coker, I'm sure they can get you 225x60 redlines.
What about??
Thanks for all of your replies. That helps out a lot! A seasoned guy who does brake conversions told me that after I put on my disc brake conversion I may find out that I don't have a rub since the disc brake conversion will push the tires out a little. Anybody think I have a shot with this or should I just order two new fronts ....225 60 R 15s?
Banned
Changing to disc brakes doesn't change the aspect ratio of the tires, I converted to disc brakes and the tires still rub.
I just got off the phone with Summit and apparently Coker isn't making the /60 redlines they show as discontinued on the Coker site. :(
When I converted my 65 to disc, I had aftermarket 14" rims (Keystone Klassic)that did not rub the front caliper because of their offset. It was close, but ordered/updated to 15" aftermarket rims and chose the offset that relatively put the tire (235x60x15)in the middle and had plenty of clearance to the caliper.
Aspect Ratio?
So it appears that the aspect ratio is what I got wrong. 70 is too much on my 65. I guess 60 was the choice I should have made. With the 60 aspect ratio I don't think anyones tires rub.
Banned
My 235/70R-15 Redline tires that came on the car are too wide and too tall but the front only rubs if I go over off camber and turn sharp.
The backs rubbed with 4 people but today I installed 1" riser blocks which added a slight rake and holds the rear just high enough that I can get 4 people in the car now without rubbing the inside of the rear fender.
I am just going to live with it until I roast these off, doesn't take long in the mountains and then put the proper 225/60R-15's on it.
I went with 15 X 7 rims, with 215 r60's in the front and 225 r60's in the rear. the 225's rubbed when I tried them on the front. running at stock height
1 - 13 of 13 Posts
