TBYRNE Motorsports is now taking pre-orders for the LS2 Predator programmers. Diablo expects to have them ready to start shipping in a few weeks so this will allow you to receive one of the first that is released.
The Predator is a state-of-the art high performance tuning flash programmer, which advances the timing, optimizes the air/fuel ratio and remaps the transmission shift points (in automatic transmissions). Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
This unit has taken the hand-held programmer to a new level. You will notice quicker acceleration and better throttle response. If you have an automatic transmission, the Predator will also give you a firmer, more responsive shift pattern (gas vehicles only at this time). The Predator will raise your rev limiter as well as it allows you to raise your top end speed limiter if you have installed high speed rated tires.
A unique feature of the Predator is that is allows you, the user, to “fine tune” DiabloSports program. Since vehicles are located at different elevations or different weather climates, the way the vehicle responds to the DiabloSport program may vary (not all vehicles are exactly alike). Some vehicles will see better gains than others and some may see better (or worse) gains than advertised. This is due to the fact that not all vehicles respond exactly the same. Now, here’s the good news…If you're not totally satisfied with the way DiabloSport program performs, the Predator allows you to make your own adjustments to the program. For example: If you feel that the shift points are too firm, you can go into the program and lower the transmission line pressure (gas vehicles). If you feel that you can benefit from a higher shift point rpm, you can go into the program and raise shift points. If you feel that you will benefit from a few more degrees of ignition timing, you can go into the program and add some timing (gas vehicles). The Predator allows you to "fine tune" the DiabloSport program to meet your specific requirements.
The Predator has diagnostic abilities near identical to GM’s Tech2 software. The predator will allow you to read diagnostic trouble codes (DTC), erase DTC’s and perform live data monitoring. You can monitor your engine sensors while driving your vehicle and much more.
Part number and pricing is -
U7191 2005 GTO/C6 Predator programmer with overnight shipping $399.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL - [email protected]
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
