How do you disable the O2 sensors that go behind the cats, I put full exhaust on my car with no cats...do they still need to be there or can you just unplug them?
what symptoms do you get if you dont turn them off. what ses lights will it trigger?
Rear O2s only test your cats. If you dont' have any or the sensors go bad, it will through a CEL. It will not effect how your car runs, only the fornt O2s do that. Since you did a full exhaust, you might wanna get your car tuned. I would assume your running rich right now and your tuner can disable the rear O2s.
I got a code for multiple mis fires and was told that could be the problem then I took it in and they said I had 3 bad ignition coils...I replaced only the 3 bad ones with no result...should I do the rest with new spark plugs?
