The odometer on my 06 gto stopped working. All other parts of the cluster work properly. speedometer and even the trip distance still reads... any ideas to what and how to fix this. thanks
Miles are saved in the cluster so I'd bet you have a bad clutster.
I don't have a "new" GTO but on my Ford truck the odo stopped working shortly before the alternator failed.
On late models since everything is electrically powered even a slight drop in voltage can cause things to go haywire. I would check battery voltage and alternator output first.
Also check the BCM wires in the dash. They can fray and do crazy things. If you search the forum you can find tons of good into about this common issue.
