Hello again, guys. For a reason that I don’t care to admit to, I had to pull and strip my motor again. Since the block is bare I figured it would be a good idea to tap the front oil gallery holes. Using a high pressure pump, those pressure plugs scare me.
Anyway, all of the reading I have done here says I should be tapping a 3/8” hole. My issue that those holes are already bigger than that. They mic out to just under 5/8”. Not only that but the hidden plug in the back of the motor as well as the one next to the distributor are 5/8”.
I measured the existing galley plugs at .60-.65. So those plugs are 5/8”. Something is askew here. I guess I should have mentioned the motor is a 389. It was my old mans car and I’m pretty sure he mentioned that the motor came out of a 65 Pontiac wagon.
Any useful knowledge would be appreciated.
Thanks guys. It never takes more than a response or two and I feel like hitting myself in the forehead for not thinking of it. You guys are a lot of help. Pops car hasn’t moved since ‘04. I was almost ready to back her out of the garage when the most recent screw up happened. Anyway. Thanks again.
Pipe plugs and thread pitches etc. seem to have their own way of measuring which is confusing to me. Best way I do it just to make sure, get a 3/8" plug and insert it in the known hole in the back of the block if it is already threaded.
3/8" is the right size for the plug. If you use them in front, make sure not to insert too deep and block/cut off the oil supply.
