........just got an estimate from the machine shop to rebuild my original 67 GTO 400cc engine.....$11,300 - $7,600 labor, $3,700 parts, the most expensive of each in parentheses below. Estimate is almost twice what they told me on the phone pre-inspection.
Anyone have experience with recent engine rebuild costs?
TIA for anyone's input.
Parts List
OIL PUMP
OIL PUMP DRIVE
TIMING SET
GASKET SET
ROCKER ARMS
PUSH RODS 8.245
CAM/LIFTER KIT
CUSTOM PISTONS W/RINGS ($1,190)
ROD BEARINGS
MAIN BEARINGS
CAM BEARINGS
BLOCK PLUG KIT
VALVE SEAT INSERT
VALVE GUIDE INSERT
VALVE SEALS
VALVE SPRINGS
INTAKE VALVE
EXHAUST VALVE
VALVE LOCKS
NGK SPARK PLUG
WATER PUMP PLATE
DIPSTICK TUBE
VALVE COVER GASKET & HARDWARE Q-JET BASE GASKET
VALLEY PAN BOLTS W/WASHERS
TIMING COVER BOLTS REAR MAIN SEAL
ROCKER ARM STUDS ROCKER ARM POLY LOCKS EXH MANIFOLD BOLT KIT JOE GIBBS BREAK-IN OIL OIL FILTER
G1015-1 ENGINE LIFT PLATE ENGINE SKID
PAINT & MATERIALS
Labor
DISMANTLE/EVALUATE ($525)
BAKE/BLAST/ CYLINDER BLOCK
MAGNAFLUX CYLINDER BLOCK
RESIZE CYLINDERS .030
SQUARE & DECK CYLINDER BLOCK
ALIGN HONE CYLINDER BLOCK
JET WASH/FINAL CLEAN CYLINDER BLOCK R&R CAM BEARINGS
R&R BLOCK PLUG KIT
BALANCE ASSEMBLY REGRIND/RADIUS/MICROPOLISH CRANKSHAFT 10/10
JETWASH/FINAL CLEAN CRANKSHAFT
R&R PISTON/ROD
RESIZE CONNECTING ROD
MAGNAFLUX RODS
JETWASH/FINAL CLEAN CONNECTING ROD SET BAKE/BLAST CYLINDER HEAD
MAGNAFLUX CYLINDER HEAD
REFACE VALVES & SEATS
INSTALL & FIT VALVE GUIDE
RESURFACE CYLINDER HEAD
INSTALL VALVE SEAT
MACHINE FOR POSITIVE SEAL UPDATE JETWASH/FINAL CLEAN ASS'T COMPONENTS RECONDITION EXHAUST MANIFOLD
PAINT ENGINE
ASSEMBLE ENGINE ($1,500)
DYNO ENGINE ($1,350)
Parts List
OIL PUMP
OIL PUMP DRIVE
TIMING SET
GASKET SET
ROCKER ARMS
PUSH RODS 8.245
CAM/LIFTER KIT
ROD BEARINGS
MAIN BEARINGS
CAM BEARINGS
BLOCK PLUG KIT
VALVE SEAT INSERT
VALVE GUIDE INSERT
VALVE SEALS
VALVE SPRINGS
INTAKE VALVE
EXHAUST VALVE
VALVE LOCKS
NGK SPARK PLUG
WATER PUMP PLATE
DIPSTICK TUBE
PAINT & MATERIALS
Labor
R&R BLOCK PLUG KIT
R&R PISTON/ROD
MAGNAFLUX RODS
INSTALL VALVE SEAT
PAINT ENGINE
