Len is located in Barstow Oklahoma.- Len WilliamsWhere is Len Williams located?
yes, 1 year parts and loborWas there some kind if Warranty on all this🧐
Yes. 1 year parts and laborWas there some kind if Warranty on all this🧐
Numbers matching engine with n block or head issues so rebuild the only option.I have no experience with these fellas, but have read several positive experiences on this forum and others. They've been around for several years now and have perfect feedback on ebay (which is hard to achieve these days with all the d-bags buying stuff there now like its Amazon):
bluemonkeyperformanceparts on eBay
Follow bluemonkeyperformanceparts on eBay. Buying, Selling, Collecting on eBay has never been more exciting!www.ebay.com
May be better to preserve your current engine as a backup and buy a complete long block from them? They look to have several 400 options under $10k, with a warranty and free shipping. may be worth reaching out to them with your desires...
$11K for a stock-ish rebuild sounds very high to me, but I'm no expert...just cheap!
Correct, numbers matching engine, which is already out. The big question is 50 hours labor for a stock rebuild (tear down, rebuild, reassemble and dyno) reasonable? They bill out at $150 per hour which although high, is not out of the range here in coastal New England.Price seems really high to me. From what I gather, you're looking at having the original numbers matching engine rebuilt? If so. Len Williams would be a great choice but he's not local to you. His shop is in Oklahoma. Are you pulling the engine yourself and delivering to the shop? If so, reach out to Darrin at Nitemare. His shop is in southern CT and he only works on Pontiac. His website only shows crazy performance builds, but I know for a fact that he does stock rebuilds. There was a stock built numbers matching 455 that was going back in it's bone stock 72 SD Firebird, in his shop when I picked up my heads from him last year.
Side note, I built my engine last year using a Len Williams short block and all the performance goodies and the cost was somewhere close to $12K. That was with having to buy the short block (assembled and ready to go with all new internals), and the heads (ported and rebuilt by Nitemare as well) with both components being supplied by the builders. Mine is far from stock sitting somewhere around 500hp, so yah, your price sounds high to me.
The shop up here (local to where live) in coastal NH) was recommended by several GTO guys in the area and has a very good reputation earned over 30 years in business. I'm not a car guy in terms of having the knowledge or ability to work on them so no choice but to have all the work done by a 3rd party. My guess is that the New Haven shop after shipping charges would be similarly priced or higher given the coast of living down there which is even higher than here. Having said that I'll give them a call.Did they provide some vaseline with that estimate?
Instead of going north, why not go south? Contact Darrin Magro, the owner/builder at Nitemare Performance in New Haven, CT. All he does is Pontiac engines and has built them for several magazine cars and has also built them for charity give-aways.
I feel a whole lot better handing a shop that specializes in Pontiac engine 11K over a non-Pontiac shop. Not saying you won't get top notch work, and my guess is he builds a lot of drag engines, so his prices reflect that.
Click on a few of these magazines you can PDF download:
Hmmmm, complete rebuild? Now here's a complete rebuild:
Engine Specifics:
Nitemare Performance:
- blueprinted 2-bolt main, 400 block
- Nitemare ported, polished &
flowbench-tested 6X Pontiac heads
-internal dipstick tube
- Pro cam plate
- Pro oil driveshaft
- Pro oil pump plate
- Pro cam washer/eccentric delete
- timing cover and pump plate
- cam and crank keys
- copper oil pump gasket
- external dipstick tube
- water neck
- water pump
cam/lifter break in will be performed at Nitemare Performance
- complete blueprinted assembly process
- full paint job
- pre-running the engine for complete ring sealing and
Scat Crankshafts:
Forged, balanced rotating assembly, including:
- Forged steel crankshaft
- Forged steel connecting rods
- Forged aluminum Keith Black pistons
- Performance piston rings
- Performance main & rod bearings
BHJ Dynamics:
-Pontiac-specific harmonic damper
Cometic Gaskets:
- Complete high-performance gasket kit, including:
- Multi-Layer Steel (MLS) head gaskets
- Intake manifold gaskets
- Valve cover gaskets
- Timing cover & water pump gaskets
- Oil pan gaskets
- Carb gasket
B&B Performance:
- Accessory drive belts
- Oil filters
- Brass freeze plug kit
- Cam bearings
- Numerous fittings
Driven Racing Oil:
- 15w-50 "BR" Break-In Oil
- Hot Rod Oil
- Defender & Booster Fuel Additive
Pertronix Performance Products:
- Plug-n-Play Billet Distributor
- Flame-Thrower High-Output Ignition Coil
- Flame-Thrower 8mm Spark Plug Wires
BOP Engineering:
- One-piece oil pan gasket
- One-piece Viton rear main seal
National Parts Warehouse:
- ARP Engine Bolt Kit
Comp Cams:
- Custom-ground camshaft
- Lifters
- Pushrods
- Pushrod guide plates
- Roller-tip rocker arms
- Rocker studs
- Valve Springs
- Valve seals
- Valve locks
Holley Performance:
- Quick Fuel Street Q 850 cfm Carburetor
as I said, Im not seeing that as reasonableCorrect, numbers matching engine, which is already out. The big question is 50 hours labor for a stock rebuild (tear down, rebuild, reassemble and dyno) reasonable? They bill out at $150 per hour which although high, is not out of the range here in coastal New England.
Well, this thread made 3 pages in less than 24 hours. To me, it sounds like you're answering your own question.The shop up here (local to where live) in coastal NH) was recommended by several GTO guys in the area and has a very good reputation earned over 30 years in business
Yes look at his web site. 400 and 455 versions. Len Williams Auto MachineAre you guys saying Les will provide a long block for less than 11k? I am not saying that I am oboard with the 11k guys just asking questions.
Crank should be the least of your worries if ground right. Good crank thread going on right now over on the PY forum.Any thought to replacing the crank and rods? Hate to see that go south when spending that kind of cash.
The crank shaft can break. I had one grenade on me and I seem to remember @Old Man Taylor running into the same thing. Keep in mind, these parts are old with thousands of heating and cooling cycles.Ironic that the Pontiac crank is over-engineered while the rods were the weakest link
Got it. Any chance you can deliver it to whatever shop you use? Does the labor hours include them installing it in your car? If so, price may not be too bad. If it's just the machine work, the build, and the dyno (I assume this is just to break in the engine) the number of hours may be high. I removed my old engine from the car, and tore down to to the bare block on a Saturday and was done by lunch time. This was my first engine removal and I am not a mechanic by trade. I started with a short block, but the top end assembly took me maybe 10 hours total and I was really taking my time with it.Correct, numbers matching engine, which is already out. The big question is 50 hours labor for a stock rebuild (tear down, rebuild, reassemble and dyno) reasonable? They bill out at $150 per hour which although high, is not out of the range here in coastal New England.
Good stuff as usual Jim!...My next car build is going to have a very cheapo Chevy old school small block that I can build for about 3K on a good day.
Does not include install (another $1,500 or so). Waiting on some numbers from another local shop without a dyno (it does run the engine of a stand before payment) that would use the same parts, Shop has been around for 30 years and also gets high marks from local enthusiasts.....would save 30% to 40% with them all on labor costs (they charge half of the other place) They're also cheaper because they don't dyno, it's a two person shop and they don't have a written warrantee. Given that this is a stock rebuild I'm leaning toward the cheaper option.Got it. Any chance you can deliver it to whatever shop you use? Does the labor hours include them installing it in your car? If so, price may not be too bad. If it's just the machine work, the build, and the dyno (I assume this is just to break in the engine) the number of hours may be high. I removed my old engine from the car, and tore down to to the bare block on a Saturday and was done by lunch time. This was my first engine removal and I am not a mechanic by trade. I started with a short block, but the top end assembly took me maybe 10 hours total and I was really taking my time with it.
