69 gto building a 461 and would like just a simple air cleaner on top on the qjet instead of the factory 2 snorkle air cleaner. I will be using the tradition pcv line from the carb to the valley pan and my question is do you have guys on the forum here have 2 breathers in either valve cover or just on the passenger? I had an oil leak out the rear main when I first got the car and the rubber hose from the air cleaner to the right valve cover was dry rotted and not sealing well. Got a new hose and breather element in the air cleaner and fixed the leak.
