I just picked up a 06 m6 yester day with 1100 miles!! Unfortunately driving home I discovered that the headlights do not work There is no warranty from the dealer and honestly I do not even think they knew about it.
The brights work, the orange side lamp work, but not the fog and headlights; all of them.
Any suggestions on a quik fix? I was thinking that its probably a fuse but there is a separate on for each lamp and they are all out.
If you do not know already to turn the fog lights on you pull the whole headlight button up. Just grab the button and pull outward. It would not be impossible for both of the low beams to be blown.
The reason I think the fog lights did not work is because you had your brights on. but other wise hopefully its a easy fix like some light bulbs.
