Hi All trying to find out year and size. Back by distributer on top of block is C 102. Head manifold has 7h1 and 350 stamped on block.
Looks like 10 March 1972 (C=March 10=day 2=year) casting 350 with the 1972 heads, 175HP 1.96/1.66 valve size with originally a 7.6 compression ratio.
Found here: Cylinder Heads
-Norm
-Norm
Yep, thats what I have in my 72 Lemans. And the actual valve size is an odd combination, 1.96/1.77. I found out on another Pontiac site from a guy who builds engines. He's seen a few 7H1's and they all have that odd valve combo.
Thanks for the help all. I Have a 68 GTO that has that engine in it. With a saginaw 4 speed. Would that engine be a good engine to rebuild? It needs alot of work. If not what is it worth?Bringing the car back from the dead slowely lol.
Tom
"Good to rebuild"? Well, that depends quite a bit on you and what you want to do with the car. If you care about value, investment or resale, then no -- having a 350 in a 68 GTO hurts it a lot. Performance? again not so good. However, if you want a relatively economical driver, it's not a bad way to go.
