1 - 13 of 13 Posts
Definitely a '71-72 hood and nose on it. Hood looks very cheesy because of the missing grills. So it's either a 71/72 or it was repaired with 71/72 parts. I really hope it's my first guess, as no '70 deserves that.
Thank you so much for that, I thought so, So now I will need to check when the car was born / repairs mods etc. Thanks a lot for your help
Also, that's more like $16,800 in US dollars. Pretty good deal, even if it is a bastardized 1970 model. Seems more likely that it's a '71 though.
it's a 71.probably a misprint or wrong title for wrong car,that happens if a seller has multiple listings of similar cars.also,the motor is painted the pontiac blue that they started in 71.
I notice no "GTO" on the driver door interior panel. Could it be a lemans cloned? That panel doen't look like what my 71 did, definitely has the seat cover that mine did. Have you seen up close?
he calls it a gto good looking? other wise looking like what. something fishy there. RUN AWAY! RUN AWAY.
Ask for the VIN number, codes from the data plate, engine and transmission, if he can't provide that information it could be a scam. A few weeks ago there was a 65 advertised with pictures of the vin tag and data plate on E-bay, it had a Pontiac, MI 5N data plate and the VIN tag was for a car built in the Fremont, CA assemble plant.
Be careful,
Discussion Starter #13
You guys are legends, I got a copy of the VIN plates and you guys are spot on its a 1971. Hey I like the 1971 I just wanted a 1970. Thanks for answering for a noob aussie. I have found a 1970 Pontiac GTO 455 with papers that will need some work so Im going to need you guys for help in future, thanks again.
2=Pontiac
42=GTO
37=2 door coupe
1=1971
P =Pontiac MI
1264487=production sequence number
1 - 13 of 13 Posts
