1 - 20 of 36 Posts
Supporting Vendor
Pontiac GTO Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your reverse light or backup light bulb (1156 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 1156-sized LED bulb, for perfect fitment in all 2004-2006 Pontiac GTO Models.
Bulb Design
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Fitment. All three bulbs use a quality aluminum 1156 terminal, with a locking base connector and proper pin alignment, designed for exact replacement of your factory 1156 bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP11: Slightly higher brightness than OEM bulbs.
XP80: Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures. Please click here to learn more about LED brightness measurement.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Supporting Vendor
Nick, do you offer the 1156 and 1157 replacement bulbs that will fit the older model GTO's?
Yes sir!
My co-worker installed our brightest 1156/1157 bulbs on his Chevelle:
It's a great way to improve your visibility at night
Feel free to give us a call if you have any questions: (314) 205-3033
Thanks,
Nick C.
How about some pics of GTOs with them?
Supporting Vendor
You should update your site, I ordered my leds from superbrightleds because you only have the option on the link listed above for 04-06 GTOs and nothing for the older cars.
We are constantly making updates to the site. It's a time consuming process (over 10,000+ listings), but if you send our team an email: [email protected] we will help you bulbs to fit your vehicle.
SuperBrightLEDs is right down the street from us, (walking distance). Although I'm disappointed we weren't able to get you LEDs, I appreciate your order with a local business.
Feel free to give us a call if you ever need help with lighting: (314) 205-3033
We are here to help!
Thanks,
Nick C
Yeah, I especially like the "4 door late model GTO's" that the site shows under 'full' and 'full2'......:lol:
Supporting Vendor
Don't be hatin'!! Lol, I'll make a note of that and have our team update the GTO listing soon.
Again, feel free to give us a call if you have any questions!
Thanks!
Nick C.
Just ordered some 1157 XM 80 amber bulbs for my 67 GTO front park/turn lights....will let everyone know how they fit and how bright they are as soon as They arrive. Great product support by telephone today. Thanks!!!!:thumbsup:
Supporting Vendor
Discussion Starter #12 (Edited)
Nice!
Thanks for ordering with us Eric
You'll have to send us some pictures with everything installed. 1967 is definitely my favorite year for the GTO
Nick C.
1 - 20 of 36 Posts
