hello. I am looking for any information on a pontiac magazine 455 560hp build around or before 2004. according to previous owner - The current 455 was purchased and rebuilt in 2004 utilizing the guide to a Pontiac Magazine 560HP build-up.
If anybody has or remembers this build I would love to read the article. I am debating going with the edelbrock heads. thanks
it has the following -
I chose to use cast-iron 1969 #62 casting cylinder heads ILO the Edelbrock aluminum RPM’s as mentioned in the article. The 455 however different by the differential in cylinder head spec. produces an immense amount of power. This motor has not been dyno tested however so the true horsepower and torque can only be speculated. I can tell you that this engine is healthy! This car is krazy fast and should be taken seriously when pressing the pedal to the floor...seriously!
a) Block: Tanked, bored .040 over and line honed
b) Pistons: Seal Power flat-tops with valve reliefs w/TRW rings
c) Rods: Stock- sized, balanced and honed with ARP studs
d) Crank: Trued and balanced
e) New bearings throughout
f) Heads: Tanked, magna-fluxed, checked for deck true and machined for new Federal Mogul valves, guides, seals and Summit Racings “pro-series” rocker arm stud kit. Edelbrock RPM springs/retainers and ARP CH bolts
g) Cam: Hyd. Competition Cams “Xtreme Energy” 284/296- 507/510 lift with *1.5 rockers.
h) Lifters: SLP heavy duty (standard bore)
i) Pushrods: Crane Energizer 5/16 x 9.170
j) Roller Rockers: Crane Energizer 7/16; 1.65 ratio (see g. above)
k) Oil Pump: Mellings 80lb. Hi Pressure
l) Timing Chain: Summit tru-roller
m) Oil Pan: Milidon gold anodized
n) 1. Intake: Edelbrock RPM with Edelbrock bolt kit 2. Carb: JET 800 cfm, Stage II, Quadrajet w/elect choke
o) 1. Fuel Pump: Holley 7lb. Electric 2. Inline filter and pressure gauge (see pics) set at 5.5
p) Ignition: MSD Pro-Billet distributor, MSD 60,000v Coil, MSD-6A multiple spark ignition control module and Summit Pro-Wires high heat silicone HEI Blue.
q) Starter: Summit Pro-Torque
r) Charging: A new 80 amp alternator was installed at time of the rebuild
s) Valve Covers: Summit Pro Tall’s/Chrome with Moroso breathers
