A few more items
offers considered
1966 1 year reclining passenger bucket seat back from toranado needs 1 small modification at the hinge
with or without ruff factory headrests and nice hardware .... 550 all or ?SOLD
1966 -71 power bucket seat track for A body ,,,, needs repair at one rear bolt hole mount... motor and transmission
works both ways ,,,goes up n down but gets stuck going forward n back.... no switch ,,or plastics
great start ...not a rust bucket ...450
66-72 B body power bucket seat track ...works all ways ... sweet part ...very nice,,, from 69 Impala...1000…. Now 850
68 GTO floor shift column nice part ...original paint from 68 cutlass,,, 225
68-72 NICE steering inter mediate shafts with nice boots ... mostly 68-9's 45 ea
68 GTO wood wheel .... its old and fugly for the tired driver worn bare couple cracks some pitting complete 275
70-72 black headrests bucket seat real nice pair 275 MINT pair 400 68 onlys also ...Sold . and 69 onlys 1single 125
69-72 stock black plastic seat backs nice originals ..... 200
69 ac parts nice core dash pad ... some duct work ... firewall stuff both sides ,... condenser ...650. Now 500
68 non air black dash pads ... 1 usable 2 need redone ....25-100
68-72 door hinge sets .... #1-sweet set of 4 blasted and dp90 tight off 40,000 mile 4 door,,,250 ... #2- set of 4 need bushings 100
#3- set of 4 decent originals need detailed tight ...150 ..... good usable passenger lower 45 ALL GM ORIGINALS
nos GM upper with old GM tag 85 ....
1967 Gto auto console with dual gate shifter
Very nice. 700. Cable brackets
Very nice and loud 71-72 gto horns. 125
66-67 low note super loud 75
LOUD pair of 68-69 horns ,,, NO issues of whimpy sound.... genuine GM sound ,,, one of the best sounding pair s I have kept out of a dozen pairs I have pack ratted .... 125
69-70 LOUi Grand Prix horns very loud
125
69-72 th350 drive shaft nice yoke real straight 200
64-65 HURST no logo early muncie shifter 4 speed .... nice for a nice driver ,,, rechrome for show ...
no linkage ....200. SOLD
1970 -72 SWEET original complete with lockout and linkage HURST 4 speed shifter very very nice SOLD
4 NOS red rally II center caps GM with clips ....MINT never used ....250 shipped
68 hub caps wire and standard ....69 hubcaps ...5-45 ea...
1968 GTO tail light buckets ... very nice originals .... all wiring un cut ... correct ground straps ...
I checked the lights and all lights work ,,, running lights... brake lights ,,, reverse .... detail em and use em
2 lens included but they are chipped
1970- 1972 a body power window conversion ... sold
3 - 67 68 8 track players untested no knobs or surounds 200 for all
69-72 SWEET floor non console 8 track player untested but super nice and
complete
69 am-fm. 1970-72 am fm. Stereo
mint 69-72 console 8 track plyw wireng
Brackeodtc. Mint. 600
68 hardtop power antenna real nice.... complete ...switch is real nice ... wiring too ...
68-72 rear window trim for 2 door hardtop ... super super nice 100-300 per set 4 sets
68 rear bumper brackets all 3 135.00
69 HURST shifter ... some NOS 67-8 linkage and levers
mounting plates ... original hardware ...
MINT clean 66-72 bellhousing ,,,show condition with correct transmission bolts ...speedometer cable bracket
inspection pan ,,, sweet flywheel ... all for 650 super nice parts ....
dated rear drums fresh pro surfacing .....67 68 69 dates
67 68 69 2 piece rotors ...turned and still within spec ... 4 piston calipers 3 or 4 sets
rear GM axles for the HD 4 pinion diffs ...
69 dated front calipers and master cylinder ,,,, brake boosters ....70 also
68 CT drum brake master cylinder need rebuild 40 fits thru 67-70 ?
67-72 manual steering box with pitman arm turns nice by hand 67 manual steering pulleys and alternator bracket
68 manual steer water pump pulley 45 NOS GM manual steering rag joint 150
date coded power steering boxes ...67-70 have a couple...
67-70 power steering main aluminum mount bracket 40
70 GTO front NOS turn signal lens/s GM and chrome bezels real GM. 150
5 blade flex fan 75
2-69-70 dual snorkel air cleaners. 2 to make 1. 100
68 69 2 bbl carbs 1 is a 69 400 2 bbl others are 350 ... a couple runners a couple nice rebuilders...
and 2 bbl air cleaners also .....
68 front turn signal buckets with the second bulb in them ... 75 pair
real nice 68 side markers rear 2/85
nice driver or better 69 GTO rear side lights 2/100.
front window stainless....68-72 ........ wheel welll opening stainless 68 69 .....
68 rally gauges w tach .... 69 rally gauges .... 70 71 rally gauges ...dash tach ....
67 rear window trim 66 too decent needs cleaning 150
70-72 vinyl top odds n ends ....
68-72 trunk springs 2/ 65
lots of 68 69 GTO grilles and hideaway parts .... bumper brackets plastics etc ....
NOS 69 up GM water pump rebuild kit ... in the GM box 100 ... impeller bearings shaft etc
sandblasted cross member 100 68 n up hardtop end caps n rubbers 25 pair
original tranny mount hardware ,,, u bolts ,,,, nice 10 bolt diff covers 25 ...rear backing plates n cables
70-72 rear seat ..... from a 70 442 real nice SOLD
lots of stuff ,,,, 5 original goodyear redline tires for show ,,,, polyglass tires ,,,65 bfgoodrich blackwall spare tire
5 sweet 14x7 rally II from grand prix 69 SJ mint rings n caps 550
69-70 floor shift tilt nice snug original black paint column ,,,, a little key rash on paint ,,, SOLD
feel free to jingle with needs ....
8 am to 9 pm pacific time 2o6 4six5 9165 call or text
Scott
Scott T
offers considered
125
complete
5 blade flex fan 75
Scott
Scott T
