Go back to the Jim Shea papers for how to bleed the Air.
His papers are the best I have read regarding Saginaw steering. No BS or "I Think". Jim was a Saginaw engineer and who else would know it better?
I'm referring to the pump in my instruction. Once its apart you'll be amazed of just how simple it is. One thing is paramount. It must be CLEAN inside. I had a stray dog hair in mine that caused loss of effort problems until I found it.
There are different versions of the pump depending on the steering gear and year. Some quick ratio 1st gen Camaros and the variable ratio 69 GP used a high pressure relief valve. As the cars got bigger, suspensions improved and quicker ratio boxes introduced, the valve changed to a higher pressure. The valve is fully interchangeable with any compatible pump. The pump housing itself changed from the 'Banjo' style to the 'Canned Ham' design but still used the same internal pump. Starting in 79 or 80 the output fitting had metric threads. Depending on the manufacturer the output fitting could have internal or external threads.
The gear housing came in two sizes. 3 1/2" for the larger cars and 3" for the A/F/G bodies. There were different variations for 4WD, trucks, Fords, Chryslers, three or four mounting ears etc. But basically it was the same from the early sixties to 2012. The only major difference was the change to metric input and output fittings in 79/80. The threads for pitman shaft and mounting ears never changed.
leepowersteering.com
Two points:
1. A mistake people make is using the Camaro/Firebird 'Quick Ratio' boxes in their A bodies. They are not a true quick ratio but have internal steering stops to prevent tire to fender rubbing. This shortens the lock to lock implying a quicker ratio. In an A body this increases the turning circle which is what Army is experiencing.
2. Another is 'Road Feel'. Road feel or steering effort can only be adjusted by changing the T or Torsion bar within the steering gear. There are different sized T bars from the factory that will provide the effort you want.
There are other ways to artificially increase or decrease steering effort by enlarging or decreasing the pump output fitting diameter. This will increase or decrease pump output pressure giving the sensation of increased or decreased effort.
A good read from LEE Steering where they explain Steering effort.
How To Identify Your Steering Gear Box - Lee Power Steering
Our comprehensive guide will help you identify your power steering gearbox. We sell & service 5 different Saginaw gearboxes: Saginaw 800/808, 708, GMT & Ford.
Two points:
Gearbox Ratio Feel Explained - Lee Power Steering
The ratio of your power steering gearbox will determine the reaction speed to your steering input. The steering valve is what gives you the feel of the road.
