I have had a whine coming from my power steering for about a year and a half. I dosen't leak or feel sluggish just very annoying. has anyone else had this issue? and where could i get a better than oem replacement for it.
OEM replacement is about $750. Google GM Part House.
I have one in my garage for an 04 if your interested. Took it out with30k miles. I upgraded to a Pedders close ration rack. I never had long tubes or anythong on it. Worked fine when installed.
I'll take picks if you want. I would sell for $140 shipped if your interested.
How is your fluid level?
The fluid seems to stay at a constant level. I usually check under the hood every couple of weeks to see how all the fluids are. I have had to add some but it was only a small amount over an 18 month span. Could it be that it's just worn out from strees?
I really appreciate the offer J but I just spent $575 on a replacement differential and it would be a while bofore i could afford it. If something changes I could contact you. Thank you though, its cool you offerd.
No problem. Hope everything works out for you.
