I wanted to try this myself. I wanted a look darker than that of the CV8R tails, but not solid black so that you can't see any light.
I also wanted to do it myself, save a few bucks and not send my car to the paint and body, or be without my tails for a week or more. Its spent enough time there already from the mexi-incident.
While I am sure that a body man could have done this "more perfect" there are zero flaws in these, and frankly I am damned impressed with the results thus far.
So here are my instructions for the project-
Time - Overnight.
Matierals - VHT Nightshades, Clearcoat (enamel),800, 1500 grit papers, 3M 1500 grit scratch and swirl remover, Zanio or Zymol cleaner wax, bucket of light soapy water, tack cloth.
Cost - about $40
Difficulty- Common sense required.
1. Sand tails with the 800 ligtly. This is so the VHT will stick.
2. clean the tails with the soapy water solution. Air dry.
3. Wipe clean with tack cloth. NO touchie. Oils from your hands will muss the job.
4. Apply nightshades using thin coats. Pretend you are a body man or a Krylon commerical. No runs no drips no errors. Do NOT lay this stuff on. Use thin coats to get the desired consistency.
1st coat-
2nd-
3rd-
4th-
5th and final, after drying.
Bear in mind these are THIN misting type coats. Can was held 10-12 inches from work.
5. Allow the stuff to dry for 6+ hours.
6. Sand tails LIGHTLY with 1500. Tack cloth the dust off.
7. Apply clearcoat. I used 4 coats of clear. the first 2 were moderately light, the last 2 heavier. You want to use a wet tehcniqe with the clear, and not a mist like with the VHT.
Clear going on-
Next to last coat-
Last coat of clear dried
Closeup - Last coat of clear dried
After the clear dires, use the 1500 3M compound to clear out the imperfections in the spray clear. You can Wetsand with 2000 before doing this.
Finally, use the Zanio or Zymol to get the nice shiny finih on the tails.
Its crappy outside and as soon as the wether breaks I will post pics of the finished product on the car.
I am sure that the job, when done by someone like (Johhny I think?) will turn out more professional or somewhat nicer. However if you are like me and cant send your tails off for a week, or dont really want to, this does a nice job imo.
Time - Overnight.
Cost - about $40
1st coat-
2nd-
3rd-
4th-
Clear going on-
Next to last coat-
