1 - 14 of 14 Posts
Hello all. I just picked up a XH 400 from a 70 grand prix. It has #13 heads.
So here's my question. Some sites call them ram air lll and some don't. Is there different#13 heads? I understand that the#12s were manual transmission and 13s were automatic transmission.
I doubt that the 70 grand prix was a ram air, probably wasn't even a option.
So was there no automatic ram air cars????
Yes they have the screw in studs and 2.11/1.77 valves.
So again why do the two sites that I took screen shots of show as auto trans ram air3 ?
The #12 and #13s show show same specs.
Did they make a automatic transmission ram air 3 car, Gto, firebird....they can't all have been manual transmission can they?
I did read this thread, but apparently the original author was mistaken for thinking all ram air heads were round port. The early ram air heads were D port. The #12s Are D port.
Now what pinion head wrote....well that makes sense, except. ..they did not use #12s on automatic transmission cars......That's where they used the #13s .
So, can anyone confirm or deny, did they make any ram air lll car that had a automatic transmission ???? ( firebird or GTO).
I'm having a hard time believing they where all 4 speeds...
I did read this thread, but apparently the original author was mistaken for thinking all ram air heads were round port. The early ram air heads were D port. The [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=12]#12 s[/URL] Are D port.
Now what pinion head wrote....well that makes sense, except. ..they did not use [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=12]#12 s[/URL] on automatic transmission cars......That's where they used the [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=13]#13 s[/URL] .
OK, #12 heads were used as RA III heads on both the manual (3-speed & 4-speed cars) with block code WS and the automatic cars with block code YZ - for the GTO
The early 1968 RA I heads #31 were D-port. The 1968 1/2 RA II #96 were round port. RA III heads for 1969-70 were D-ports and RA IV were round ports.
Looking at the Firebird engines, for 1970, I see heads 12/13 listed as RA III on the 400CI automatic car & #12 for the manual.
The difference between #12 & #13 with regards to the Firebird are unknown to me. It may be that they were used after a specific date post #12 heads. But regards to the GTO, #12 is the correct RA III head.
Just found this from another website: "70-RAIII(d-port) m/t FB's and GTO's used #12's. With a/c #13's. Some auto's w/o a/c got 13's too."
From another Trans-Am site, the #13's were typically for automatic cars, but 12/13 seem to be interchangeable for the F-Body cars only as RA III heads.
Discussion Starter #8 (Edited)
OK Jim I respect your knowledge. I just find lots of conflicting info out there. For example this firebird engine was rated at 345hp but it was the same engine they put in the Gto (YZ with #13 heads auto tranny).....they underrated it at 345hp to meet GMs specs for power to weight ratio.
So I guess my initial question about 2 different #13 heads can be explained.
Maybe GM took the time to hand cc each head and take the ones with a slightly larger combustion chamber to use on the XH engine (350hp auto trans grand prix)......and then they took the tighter combustion cc heads for the good cars like Gto and firebird.....and then they could lie about the hp so it meets the Gm power to weight ratio. ( chart in second picture for 345hp YZ engine auto tranny 13 head specifically listed as ram air lll).
I see lots of conflicting info....The screen shots I provide show #13 used on YZ and XH auto engines.
Thanks for sharing your knowledge Jim, sincerely Matt
Yep, Pontiac played with HP numbers. The GTO & Firebird 400 engines were the same. The difference in keeping the weight to HP within GM guidelines was to limit the amount the secondaries on the carb opened up. This was easy enough to get around and many made the adjustment to get the full 360 HP.
I don't think Pontiac would have measured CC's of the chamber and set them aside and use them on one engine line versus another engine line as they were all machined. Typically, the cc's are more than advertised, so 72 cc's were more likely 75 cc's. The advertised cc's were used for those who would run their cars at the drags under specific divisions and then NHRA or IHRA had their minimum numbers a head chamber size could be.
In general, most big valve D-port heads flow close to the same. The casting numbers are more important to those wanting number matching or replacement numbers matching when the engine/heads are MIA. The head chamber cc's, big valves, & screw-in studs are what most look at when selecting a performance head for their engine project, and often to get a compression ratio that can use pump gas if high octane or gas additives are not wanted.
Factory published literature.
YS and WS engines received the same cylinder heads. If the MPC can be trusted, then all RA III had the same heads irregardless of transmission or body style (Firebird/GTO).
Also, same part number is shown for all manual transmission 400 cubic inch manual trans 4 bbl Firebird or Tempest.
This means #12 heads would be for all RA III applications and for any Firebird or Tempest with the 400 cubic inch V8, manual trans and 4 barrel carb.
The #13 head is for 400 cubic inch V8, M40 auto trans with 4 barrel carb used in Firebird, Tempest and Grand Prix. None of the factory literature that I have shows the #13 head for any other application other then the base 400 auto 4bbl engines.
Summary:
#13 heads are NOT RA III
#12 heads could be RA III
Information found on the internet should be used for reference and not actual gospel without cross referencing with other verifiable sources such as factory published data. Does go both ways though....there are irregularities in factory literature but it's not rampant.
Sent from my SM-G930V using Tapatalk
The [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=13]#13 [/URL] head is for 400 cubic inch V8, M40 auto trans with 4 barrel carb used in Firebird, Tempest and Grand Prix. None of the factory literature that I have shows the [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=13]#13 [/URL] head for any other application other then the base 400 auto 4bbl engines.
Summary:
[URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=13]#13 [/URL] heads are NOT RA III
Your info may indeed be more accurate. I got the 12/13 RA III heads for the Firebird from the Pete McCarthy book and what was posted on the Trans-Am/Firebird forums with regards to the #13 heads. And yes, on the B-body cars too. So, one of those conflicting Pontiac things?
Your info may indeed be more accurate. I got the 12/13 RA III heads for the Firebird from the Pete McCarthy book and what was posted on the Trans-Am/Firebird forums with regards to the [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=13]#13 [/URL] heads. And yes, on the B-body cars too. So, one of those conflicting Pontiac things?
I think I remember reading some owners of RA III cars reported they came with #13 heads from the factory. I don't remember if those claims were validated though... ??
Thinking out loud...
The complete engines were assembled at the engine plant before shipping out to the various assembly plants across the country. Each 2 character engine code was a recipe for how the engine was to be built. Part of that recipe was the cylinder head....which was a sub-assembly itself.
I expect the cylinder heads were machined and fitted with valves, springs, plugs etc and then moved to a "pick area" for use with the appropriate complete engine recipe. I have always wondered what method was used to identify the cylinder head assemblies from each other. Did the cast numbers at the siamese ports serve this purpose? If so, then all RA III engines called for #12 heads and that is what they all should have received.
Step back a few years to 1967. The basic cylinder head cast number at the center exhaust ports is 670. Yet we know of at least 3 different valve/spring arrangements for various engine codes. In order to identify the different cylinder head sub-assemblies, it appears the cylinder heads received a stamp on one of the round pads cast into the center exhaust ports. I don't remember the details but I think blank might have been for 2 bbl and 4bbl auto applications, Z for 4 bbl manual and X for RA engines. I wonder if this practice was abandoned for the 1968 model year on since it could have been unreliable.
Conventional wisdom says if the cast number is different.....the casting is different. So there has to be some physical difference between the #12 and #13 heads. No clue what that difference might be though...
On a different note....but possibly related to this topic. We all have seen the performance engine specifications document for 1970 so we know there was conflicting information in there related to the WT engines related to 2 bolt vs 4 bolt mains.
Hard to say 50 years later what may or may not have happened. :) Still fun to discuss.
Discussion Starter #13
Yes exactly what I was finding, pontiac power.com shows as ra3 and classic Pontiac. Com also, but Wallace and Butler don't mention anything about ra3, so yes conflicting info and that is why I asked the question. I also just read that they used the #13 heads on air conditioned cars.
Well thank you both for the info, I have learned tons of good info here!
All good points. I think it fair to say that Pontiac used different procedures & techniques that did not always follow protocol.
I don't know what the actual differences, if any, between the #12 & #13 heads would have been. I would think that the castings were the same, but I wonder if the chambers may have been a little larger (providing let's say 10.5 versus 10.0 compression) seeing they were used on the Firebirds with automatics. Automatic cars got a slightly milder cam and the lower compression would compliment the milder cams used on the automatics. With the B-body cars, they were not really performance orientated so a slightly lowered compression to start with seems fitting and then you had a different cam installation depending on transmission type.
1970 was leading into the reduced compression ratio's and net vs gross HP of the 1971 models. So it would also be interesting to compare date codes on #12 heads used on the Firebirds versus the #13 's used on the Firebirds to see if they co-existed at the same time or if the #12 's were superseded by the #13 's at/near a specific month/day through a Bulletin announcement like the change over to screw-in rocker arm studs on the [URL=https://www.gtoforum.com/usertag.php?do=list&action=hash&hash=4]#4 X[/URL] heads which were at first press-in studs and later screw-in studs - "With the discovery of issue #4 of the 1973 Craftsman Service News set, all theories were validated with a simple, one-paragraph statement on page 54 entitled, “Threaded Rocker Arm Studs”. The paragraph clearly states that all Pontiac V-8 engines would receive threaded rocker arm studs beginning with engine #709986 which was assembled on or about May 7, 1973 and would carry throughout the remainder of 1973 engine production and on to 1974.
But, if I were a betting man, my money would be on a chamber CC difference with the #13 's be slightly larger to reduce compression on the Firebird/Trans-Ams with automatics and yet still be called the RA III heads along with all the RA III specific items that were included in that package option. :thumbsup:
1 - 14 of 14 Posts
