Im trying to figure out my elec problem. One is the tach. While looking under the dash at the steering column there is a brown wire Im surre its froim the distributor to the tach, where it goes through the fire wall its spliced and connected with a plastic connection, its large and connectable, when I took it apart inside is a globe of metal and the wire has a ball that connects to it. I noticed the wire and globe werent connected very well so I pushed them together but the two pieces back to gether as tight as I could, then started the engine. The tach is working a bit better, it now goes up to 2000rpm instead of just sitting at 1000 when revved up. Whats the connection for? Can I get rid of it and connect them together permanately? maybe then the tach will work properly.
I talked to the former owner and the wiring was or is all new except the headlight. Thats where the problem is. The battery light comes on when you turn the switch down and dim the lights the battery light goes off.
I took it apart, the switch, and tried to individually test each connection in the switch to see which one lights the battery light but the switch wont dim when removed from the dash. Im going to try to put it together today out of the dash see if I can get it to work that way, or short out that way whatever the f***k is going on. Nice of him to sell me a car like this.
