1 - 12 of 12 Posts
RIP (12/27/60-7/18/15)
Now that I have buggered up my radiator drain plug.
Looking forward..........Im assuming (now) that the nut must be loosened CCW then the other part turned cw to drain?
thanks as always
I use a little neversez on the threads. First time I drained the radiator I could not loosen mine it was corroded. Replaced it with an AutoZone POS and found upon refilling the radiator the draincock was bad.... It worked fine before refilling.... Took the OEM one on the vise and opened it with vise grips wire brushed it well applied neverseze and it works swell now.
What pontiac said. It's freewheeling and it's done. Take the old one off and replace it. (or just loosen the shaft with vice grips and tighten it back up if you want to bugger it even more!!!!) :)
We're ALL getting carpal tunnel, and Topkats hands are getting so beat up he can barely work the bottle opener.........
1 - 12 of 12 Posts
