1 - 15 of 15 Posts
Radiator, Hi guys. Need to make vice on a new radiator for my 1966 Pontiac GTO with the air conditioning. Must’ve picked up a rock or something it’s got a hole in the middle of the radiator and I don’t wanna try and get it fixed. Thanks for any suggestions
Discussion Starter #2
Been doing a little research not much. Northern radiator or cold case radiator. Which one do you suggest or Something different
Northern radiator seems pretty expensive. Looked at Champion radiator. Seems more reasonable but I don’t like the top tank look. Looking for something that’s more stock in appearance. So far cool case is the only one. Would really appreciate some input from you guys. Thanks
You might find something by doing a Google search in the upper right hand corner. Other projects have had radiator suggestions.
My opinion is that you just pick one and go with it. The subject is like asking which oil is best. You can do a bigger web search and find pro's and con's on just about every radiator out there. Lot of personal opinions. :thumbsup:
Try US Radiator, they make them just like original, look good. I had them make me a four core just like I had but added bigger down tubes for better cooling. Just google them and check the website,...
You can call them they were very helpful, good luck
I bought a 3 or 4 core radiator from ECP Engineering cooling products for my camaro off of Ebay 3/4 years ago. Working great.Got a large two row from ebay as well. Looks close to original and fit well. Just have not tried it yet. Here is a pic. Search ebay for 67 gto aluminum radiator when you find this one click to see it then get on see other items and look for the one you need.
When I did mine, the rad shop replaced just the core and left the upper and lower tank in place. Stays original....sort of!
About 2 years ago, I replaced the original radiator in my '71 GTO, with one from Cold Case. To my knowledge, nothing wrong with the original except it was old and I wanted a more modern one. Didn't want to take any chances. The Cold Case bolted right in and looks just like it belongs there. No problems thus far.
Should also mention that I bought an all welded, 2 row aluminum radiator, from Intercity Car Parts, in Ohio, for my '62 SS 409. It looks well constructed and bolted right in. I don't think it has a manufacturer's name on it. Probably an import from China. This radiator was almost half the price of others for what I think is pretty much the same thing. I think that is what got my attention. This radiator works perfectly. Keeps my 409 engine at 180-185 degrees all day long on a hot July day. I have no complaints about the Cold Case radiator. Certainly a well constructed radiator. To do over again, I think I would have looked at Intercity to see if they might have one for my GTO, Nicholas.
I meant Auto City Classics; not Intercity Car Parts. My apologies, Nicholas.
If you are trying to maintain a Concourse correct car, have your Harrison radiator re-cored. If your not going for Concourse then any of the previous suggestions would work.
Sent from my iPhone using Tapatalk
Discussion Starter #13
Thanks everyone for the suggestions. Here’s the update. Lol. It’s not the radiator. What I thought to be a hole was just a bunch of debris in the middle of the radiator. When I got it out it looks like just the fins were kind of banded up a little bit. I even took the radiator into a radiator shop and he submerged it in his tank and pump air into it and no bubbles. .. So, Why do I see a small amount of fluid on the bottom of the radiator after I start the car. Here’s two guesses. First one it might’ve been that the radiator cap was leaking or the overflow tube was leaking onto the bottom of the radiator. I have change the radiator cap and re-routed the overflow hose. As you all probably know I don’t have a recovery tank.... 66 GTO did not have one. The other one I think is a little more serious if true. It could be the water pump. I’m thinking the front seal might have a very small leak and on initial start up it throws some coolant out onto the fan and transfers to the radiator and dribbles down. What are your thoughts. Thanks again for everyone that has participated.
My vote is the radiator cap seal. I have had these go and you lose just enough so it evaporates and you can't find the leak, but you are losing water. The overflow hose if too short could probably spit some antifreeze out onto the lower radiator - which could also be an indication the radiator cap seal was gone and not holding pressure allowing antifreeze to get pushed out.
Don't think it would be the water pump splashing. The fan draws air through the radiator, not pushes it, so if you were getting splash back, I would think it would be an obvious leak.
So let it ride for now and see if the leak stops with the repairs you made and then go from there.
1 - 15 of 15 Posts
