Did anybody replace his stock Blaupunkt radio with a different kind of radio? I would like to have a radio with MP3/WMA support... I found some an their size is 2 DIN. Will that fit? And what about the connections in the back?
Thank y'all
Hi, CrazyGerman, welcome to the forums! The stock radio in our Goats is a double din, so the ones you found should fit, but you may still need a mount kit, depending on the radio you get. As for the connectors, Radio Shack sells a direct plug-in adaptor harnes for our cars, but it is not listed under GM cars in their computers. It is listed under "European".
That will require another adapter harness, that only works with certain radios. (to the best of my knoledge)
