I got the 400 in the car and now i ran into the infamous Pontiac pulley alignment issue...the pulleys of water pump, alternator and ps pulley all match up. But the lower crank pulley dont match up with the water pump. It appears if the lower crank could go in further it would match but its in as far as it will go. Short off converting and switching everything will a wp spacer push out the wp pulley work?
Car is a 75 block
Pulleys came off my 69 block. So that appears to be the issue?
The wp is 4.5 for both 69 and 75 block so that cant be the problem.
On my 1969 400 b4 engine went bad never had pulley issues and these the same ones.
Finally only thing i changed on the 75 block was i installed a new Harmonic balancer.
Car is a 75 block
