OK, if you recall, I originally was getting some help with the rear axle numbers and it believe it cam from a 1969 Chevelle. I found some carrier stamping numbers that I need some help with. Here are the stamping numbers:
3969278 NF
Can anyone help me decode these stamping numbers? Also, I confirmed that the rear axle is a 12 bolt (Non-Posi) 4-link Axle. two at the top and 2 on the bottom The coil springs sit on the rear axle so I think that means its a coil over rear axle. I think this is the Safe-T Track setup.
Again, the stamping number on the AXLE says: KD 0 or a 6 3362
The Carrier stamping numbers are: 3969278 NF
Any information would be greatly appreciated.
Lucas:shutme
Lucas:shutme
Safe -T-Track is just another way of saying "posi". Since you already confirmed that it's not a posi, then, it's not a safe-t-track.
