Hi Guys,
Found a Posi rear end with 3:08 gears from a 1967 GTO.
Been hearing from some of you guys that 3:08 is a pretty good all around gear ratio to go with.
Have a 4 Speed set up to match.
Question is: Will a '67 GTO rear end fit into a '69 GTO ?
What are any differences ?
Been told '68 - '72, but found this one... a '67
Appreciate the advice & help.
Lfryklu
It'll bolt right in. I installed a '69 GTO rear end in my '67 GTO, and it's an exact match. No difference at all except the casting numbers. Go for it. You'll love the 3.08's in a street car if you ever drive over 50 mph.
i believe the 69' would be around a half inch wider overall, otherwise they are the same but that just means you can get a little wider tire in there now.
