Hey all,
Currently my 65 rear suspension features:
Hotchkis springs, KYB gas shocks, Polygraphite bushings
Chevelle (12-bolt) upper control arms, boxed lower GTO control arms to accept a 1-inch rear stabilizer bar.
12-bolt Posi rear out of a ’66 Chevelle
Goodrich 265/60R16, stock wheel wells
I am getting tire rub on the passenger side (frame) when making a moderate left turn. There is no more then one-inch clearance between the tire wall and the framel
Time to change tire size? Recommendation?
I am also considering a suspension upgrade. Would a dual coil over solution due the trick without changing the tire size?
What is the best supplier you recommend?
Try the spacers I referenced in your other post. Here is one that is 1/8". I think more searching might turn up 1/16".
