thanks I looked at them real nice good price. Did you get the replacement bushings too? $50 for the 2My Spohn arms were 210.00 on ebay.
Yupthanks I looked at them real nice good price. Did you get the replacement bushings too? $50 for the 2
Those are expensive whats the deal with them why so much? Wasnt sure which one needs to be removed thanks.It will not be easy to replace the differential bushings. For my El Camino, I drilled a series of holes around the circumference of the bushing then knocked it out. Then with a hammer and chisel knocked out the outer shell. Thats the easy part.
The hard part was installing the new rubber bushings. I froze mine for a day or two, lubricated them and then used a 5# hammer to 'insert' them. Not much room to swing the hammer. And it's possible to break the ear off the differential if you accidentally hit it. There is a tool available to press therm in.
If using poly bushings it should be easier.
With my 68 I used UMI Roto-Joints. Lightly tapped into place and retained with a lock ring.
Rear End Housing Bushings Archives - UMI Performance Inc.
www.umiperformance.com
View attachment 161240 View attachment 161241
The diff bushings are a PITA. If you have access to a lift, i strongly recommend. I love how Army does this “ On back, driveway, 15 degrees etc” lol . I bought all new UMI upper and lowers and the upper sucked A**. Not gonna lie. They were original, 52yo crap and dug in but good. Purchase the bushing removal tool online, it is huge help. Simple and cheap but super helpful. Follow the other guys advice for all the install. But damn Army, why can’t the driveway God live on the West coast!Those are expensive whats the deal with them why so much? Wasnt sure which one needs to be removed thanks.
Thanks bro! You wouldnt have one you would like to sell ? The tool remover. I just hate buying tools for an hours worth of work then selling it for 25% of what I paid i have several tools I'll never use again. One is a oil pressure gauge I went through 3 brake bleeding kits until I got a syringe with a clear hose that worked without a bunch of bubbles. I have a hotrod master cylinder so I couldnt use one of the bottle full of brake fluid at the master cyl type. It was only $20 but it works well.The diff bushings are a PITA. If you have access to a lift, i strongly recommend. I love how Army does this “ On back, driveway, 15 degrees etc” lol . I bought all new UMI upper and lowers and the upper sucked A**. Not gonna lie. They were original, 52yo crap and dug in but good. Purchase the bushing removal tool online, it is huge help. Simple and cheap but super helpful. Follow the other guys advice for all the install. But damn Army, why can’t the driveway God live on the West coast!
Sure. I certainly don't need it. PM me and we can connect? I'm in PacNW area. JoeThanks bro! You wouldnt have one you would like to sell ? The tool remover. I just hate buying tools for an hours worth of work then selling it for 25% of what I paid i have several tools I'll never use again. One is a oil pressure gauge I went through 3 brake bleeding kits until I got a syringe with a clear hose that worked without a bunch of bubbles. I have a hotrod master cylinder so I couldnt use one of the bottle full of brake fluid at the master cyl type. It was only $20 but it works well.
You wouldnt have a bushing remover want to sell would you?My Spohn arms were 210.00 on ebay.
No I have to rent one to put these in, Oriellys takes a deposit for the tool then when you return it you get that back.You wouldnt have a bushing remover want to sell would you?
Zero bind! 100% articulation = TRACTION and no wheel hop!Those are expensive whats the deal with them why so much? Wasnt sure which one needs to be removed thanks.
Don't confuse "How I do it" with "How I wish I could do it"!I love how Army does this “ On back, driveway, 15 degrees etc” lol .
