Document ID# 1680310
2004 Pontiac GTO
Dana Rear Axle Engineering Exchange Program - keywords broken chatter growl leak noise vibration whine #PIP3387A - (Jun 30, 2005)
2004-2005 Pontiac GTO
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Any concern with the rear axle in the 2004-2005 Pontiac GTO.
Recommendation/Instructions:
Dana Axle has provided 20 rear Axles for the 2004/2005 GTOs. They would like them exchanged for major failed units and axle whine for engineering analysis.
Currently, this stock of axles has been depleted but more feedback from the field is desired. If an axle is required for one of these vehicles, please contact the PQC at 1-800-654-7654 so that you can be placed on the list for shipment when an axle becomes available.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2004 Pontiac GTO
