Lifters do not ride center on a cam lobe - they ride a little offset by design to cause lifter rotation.
Bearings are not good at all. Something going on there. Scratched up for the most parts and then the sides at the bearing part show no wear at all. It can be the result of oil starvation - lack of oil due to not enough bearing clearance or loss of oil pressure.
Could be other issues like crank journals out of round or bent crank - both of which require a shop to check.
Did you also check for crankshaft endplay?
Here is a PDF that will have some bearing failure info:
