So you may have seem me talk about this on the forum before. But I do recommend that you drop a bottle of Redline S1 Complete fuel System cleaner in your next full tank of gas. It goes right in the gas tank, then fill it up.
Here is why most the additives are snake oil, they drain your wallet and make some smoke.
There are only a few products that contain the one real chemical that can clean your carb and fuel system and even your valves, because it can withstand the temperature of combustion and dissolves the crud.
In the early 1990’s the chemists at Chevron Oil Company developed a chemical additive for their gasoline that did all these things. They add to their gasoline still today and advertise it as well, it is Poly Ether Amine (PEA), ....the trade name, or brand name is “Techron”.
You can actually buy Techron in a bottle at any auto parts store, even at Wal-Mart. But Redline actually has more Techron in it’s bottle than in the Techron bottle. In addition Redline uses two chemical carriers for the Techron, one is an octane booster and one is an upper cylinder lubricant. Both good things.
So you don’t need to know all this, just get a bottle at you local parts store and use it. It will keep your fuel system in top shape. I use a small bit on every fill to keep things in top shape.
That fighter jet might need some too...
