Thanks PJ!
Just got my filter kit. Here is what it looks like when you receive it. You have to do some assembly.Thanks PJ!
Yep, I thought the same thing. But, I feel better knowing that all the parts are correct and matching and that the set-up is spec'd and used by a Pontiac engine builder.Funny that is a pretty basic setup for so much money....I still need to do research on other options (never heard of these guys) and would like to understand why their setup is better than others.
Working through relocation right now in my ‘67. Impossible to keep the stock filter setup with my headers. Would love serials on what and where you ran the remote setup.Jim, I ran a single remote filter on my '66 GTO for over 10 years with zero problems. With the headers I was running, it sure made oil changes a snap. With the large Ford type filter and the hoses, it also added to my oil capacity, which I see as a good thing.
I use the same set up, dual filters. Get hoses made at O'reilly. Love it, except when changing oil. Mounted high on fender well.Had this setup for over 10 years on my 70.
No problems.....
yeah, but over engineering is better than having to do the same job twice.Just got my filter kit. Here is what it looks like when you receive it. You have to do some assembly.
Instructions are included. There is one length of braided line. You have to cut it (die grinder & cut-off wheel) and assemble the ends. It is this way for mounting purposes depending on where you locate it. If you are not comfortable doing the cutting/assembly, you could bring the measurements and the parts to a local hydraulics rebuilder/shop. They can do this for you. I have a local shop near my workplace that makes braided steel lines as well as rubber lines.
I don't see any other issues, per say. The bracket to hold the oil filter looks adequate, but I might add/weld a couple steel diamond shaped gussets at the 90 degree bends just to give it a little more "beef" - just because I like to over engineer stuff. LOL I'll have to re-paint, but no big deal. Another alternative would even be to have the bracket made up at your local metal/fab shop using stainless steel. Use the painted bracket as your template and let them duplicate it so it adds a little "shine" to the firewall.
I am probably going to use a finned oil filter cover of sorts to match my finned valve covers. There are different styles available. I don't think I want a full cover, but maybe a partial "vaned" cooling sleeve might look good. Included a picture of one. They are available in colors as well.
Ya, we see it. Just waiting on photos of your breathers to get things started, then we may or may not answer you.Idk if my post can be seen in this old thread because it doesn't appear as a new post.
