i replaced both front hubs on my 06 now traction control turns off by its self & cruise control will disenguage while running down the road !
any ideas in this?
also installed a 7" touch screen at the same time.
well driving home today my info center flashed check alt , abs & brake one right after the other . so i get home pull hot & ground term off cleaned them & put back on started & let run for 15 minutes traction control stayed on as it should & no other issues !
finally figured it out ! had a blue tooth obd2 scanner plugged in to send info to my radio. took it out & in 100 miles now no issues!
