I need to buy a new hood for my 67 and there is a guy with a new one that he got from aimes that he dosent need now.Is there a differance from where the hood comes from as far as how good they are ?Also where would be the best place to get a disc brake kit.
As far as I know, the hood is either made by DYNACORN or GOODMARK. The vendor should tell you. I can't help with the disc brake question, as I used a "custom' WILWOOD set-up. Eric
P.S. If you use the aftermarket hood, use the aftermarket scoop insert also. The fit will be better.
