I have an 06 GTO and per the manual , to rest the service engine oil display on the instrument panel says to turn the key to ON position, then press the acclerator petal down and release slowly twice within 5 seconds.
This doesn't work.
After a little searching, I found out per GM, you turn the key to ON position, let the display settle, then press and release the gas pedal 3 times real fast, then wait for about 30 seconds, it should reset. And it did.
Who the hell writes these manuals anyway??? LOL
Just thought I'd let anyone know incase they run into the same problem.
This doesn't work.
