With the help of you on here and the Ames catalog I have redone the pcv, booster connections to what I hope is correct. The booster and vac.advance are coming off back of carb. Would appreciate any input.
Looks real clean, The only thing that jumps out at me if the Booster Vacuum tube.
Looks very tight/close and riding above/on the return spring, I would re-route so it goes behind the bracket rather then in front.
JM2C
The wheel wells need to be closed also, get some 1/8" neoprene from Amazon & aluminum thread from hardware store to make your own staples alot easier than the real ones.
