1 - 10 of 10 Posts
Here are the installation instructions:
http://www.bmracing.com/malloy/GTOinstructions.pdf
To answer your question, it is a somewhat difficult install as there are four bolts that you can only access by reaching up and around the transmission. You either need to be very limber -- or have an assortment of extensions and joints to get at it.
All the bolts need to be set with red Loctite -- and you HAVE TO apply to the RTV sealant around the transmission opening -- not the base of the shifter as written in the instructions -- otherwise, there's a higher chance that it may leak.
Regarding looks -- it looks just like the factory unit as the stock knob and boot are retained. As far as performance is concerned, it makes a world of difference.
I have a GMM Street version. It has to be the most precise shifter in the world. I have read many posts, especially on the other forum about B&Ms that the bolts come loose despite Locktiting them and about bolts just shearing off. I think the general concensus is the the GMM is a better shifter.
After I put mine in I let my brother drive it. After the ride he immediately ordered one for his GTO.
**DO NOT BUY OR INSTALL THE B&M SHIFTER**
It is a poorly-designed unit that will come loose and leak...again and again. There are dozens od documented cases of this- I am not in alone.
The GMM Race shifter is a much better unit, a superior design that will stay on the tranny. The feel is much better as well.
Critique below lifter from another site. But it outlines the crappy PoS which is the B&M (on the right, GMM on the left).
You've been warned.
In, meaning it's in the car? Damnit. I Hope I installed it corectly. Everything was locktighted. And not the lock tight that they give you with the shifter. I Used extra high strength stuff. As for the bolts breaking all I can do is pray. If it happens im gonna have to order a GMM.:eek:
Sorry, I'm just not buying the "all B&M's are bad" line -- as my properly installed B&M is fine.
While the GMM has a slightly better, more positive, mechanical feel -- it doesn't justify the cost -- as it goes through the gears the exact same way.
Don't worry about your unit -- you should be fine.
1 - 10 of 10 Posts
