I have the Roady2 XM Sat radio and I'm still deciding on location , Just enjoying the sound even thru the wireless FM Modulator. Makes the commute so much nicer : Watercolors is CD quality. I've Tryed the Passenger A/C vent and tryed the center stash bin... Thinking the included mount may work above the mode/set switch ... Also researching a gooseneck mounting arm on passenger side trans wall . Also a extended suction cup above the mirror against the headliner ... The antenna works fine for me on the piece of metal behind the rear passenger headrest (3 bars) , also works fine as a temp on the rear speaker grill.
Also my rear tint is non-metallic so it presents no problem. Also set my FM2 presets to match the FM frequencies available so if static appears I can try another input...
I have not decided on a location yet , just sitting it in cup holder while I analyze ... Started this Thread as a location for Roady2 XM shared info...
