As you can see the body is done metal wise and in etch primer. Here are some pictures of the suspension. Went with The Right Stuff four wheel power disk all the way around. Lowered the front 2".
I delivered the rolling chassis to the shop on Friday so it can be reunited with the body. I'll post some pictures when I get it back home. I was hoping to take it right to the shop doing the final body and paint but his shop is at capacity at the moment. I'll just keep going with the restoration of components.
Looks great. I see that you added the rear sway bar - good choice. However, might I suggest that you add the upper/lower control arm braces. This will tie the 2 together and eliminate frame flex if you "use" the power of the engine. I like/used the UMI brand on my 1968 Lemans that I am rebuilding. This has been covered before on the forum's. 1964-1967 GM A-Body Control Arm Reinforcements/Frame Braces [4029] - $129.99 : UMI Performance, Inc. It is a bolt-in with all the parts you need - very easy. These arms have a slight bend to them to clear the floor pan as some brands can hit and you might have to do a little floor adjusting with the hammer. They are also adjustable so this makes it real easy to get your bolts lined up as frames/mounts are not always perfect.
Here is a lesser expensive version, and a copy of what the factory offered on the 4-speed cars, but they have no adjustments should you have any frame issues and they are not as heavy-duty as the UMI pieces. They don't need any additional bolts like the UMI set as they are flat stock and you would use your existing control arm bolts. There is nothing wrong with these and they are certainly better than no braces. https://www.yearone.com/Product/1964-72-gto/fp199#prettyPhoto
Thanks Jim,
I'll take all the suggestions you have. The car is actually a four speed just haven't got the new floor cut yet. It has the factory reinforcements but I'm going to have a closer look at those UMI parts. I have used their stuff before and it's great.
She is mated back to the frame. Here are a few pictures. All metal now, rust is completely gone. Unfortunately I had to bring it back home instead of right to the painter. He is booked up, I'll start detailing components and wait my turn. He does beautiful work so it's worth the wait.
Well I got the call from the painter last week! Delivered it to his shop last night. Now I have some room in the garage to work on the components. I'll post some pictures as he progresses.
Starting to dig in on some of the sub assemblies while the car is at the painter. I'm way behind as I was tied up with some home improvement projects. Feels good to put something on the shelf complete and ready for install when the car comes back. Not going for factory correct, I'll detail the items that will show and make a difference. Items like this that are under the dash, I just want paint on it so it's clean and won't rust.
Here are a few of my first, "almost" finished piece of stainless trim. I did all the polishing on a previous restoration but I had forgotten how time consuming and tedious this was. If anyone has some tips or secrets I'm all ears.
Car looks beautiful ! A couple of quick questions:
(1) When the body was stripped, it looks like you painted the interior floors with a black coating. What did you use?
(2) What did you paint your pedal assembly with color and brand ?
(3) What size wheels did you get ?
(4) Do you have any pictures of the finished painted interior ? I am trying to decide on color and am interested in what people do on the inside vs. outside.
Hope you did not do the vinyl top. My GTO had a factory one. When it went for the big repaint job, painter stripped off the vinyl top and found surface rust and pinholes (AAARRRGGH). Anyway, he repaired the metal, used quality primer, bc/cc, and she is looking good. With the potential rusting issues, I would never have another vinyl top. FWIW
Chris,
The product I used on the floors inside and underneath is called Raptor. There are several similar products out there, another is called Lizard skin. Very similar to a bed liner.
I think I used the gloss black industrial paint in the spray bomb from Rustoleum. I use an etch primer first then topcoat.
Rear wheels are 18 x 9.5 and fronts are 17 x 8.
I'll try and get some of the interior. It's just a black my painter uses on most of his GM restos. I beleive it has what he calls a 20 or 40% flatening agent in it to reduce the glare off the dash.
Haven't bit the bullet on the top yet, thanks for the input. I have been thinking about alternatives but it will never see rain anyway.
Thanks, Rob
Chris,
Thanks, Rob
Clutch Pedal & Rod Parts List
1 - Grade 5 7/16" x 5" Bolt
2 - INA SCE78 Shell Type Needle Bearing 7/16" ID x 5/8" OD x 1/2" W.
1 - Kit (4 pcs) Clutch/Brake Pedal Shaft Bushings
2 - 1/2"-20 Thread x 1/2" Dia. Hole Right Hand Heim Joint
1 - 3/8" ID x 1/2" OD x 1" L Steel Spacer
1 - Grade 8...
1 - Grade 8...
First time poster and thought I would take a moment and share the details of my GTO frame off restoration. I have a 66’ GTO convertible that’s been in the family since almost day 1. The car came off the showroom floor in Missoula, MT. It’s the car my parents drove off in when they got married...
I am in the process of obtaining a 68 GTO that is what could be called "umolested". Numbers matching engine, verified relatively low mileage, all original body, etc. The drum brakes, including power booster, master cylinder, and maybe drum brake components need attention as the car is unsafe...
I want to put 3 point seat belts in my 65 GTO instead of refreshing the bucket seat original lap belts. From what I have read, it looks like designs for convertibles ( with a new attachment point in the door pillar) could work. It will make access to the rear seat even more awkward, but the...
