I've got an 04 goat sometimes it starts to idle rough with the rpm's staying steady? I posted this problem awhile ago but the rpm's were fluctuating while it was idling rough, why is it running rough with the rpm's staying steady? What could this be?
check for a vaccume leak, if you have a c a i., oil maybe on the maf, check connections to tb and maf, clean maf and throttle body. you can spry the maf dont wipe. let it dry. do all this when the car is cold. wipe only the tb dont spry in it. there's throttle body cleaner and there's maf cleaner. dont mix them up. try that. good luck
